Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. HiHoStevo
    HiHoStevo Airport Bum
    40
    Las Vegas, NV / Cedar Hills, UT
    Sean, thank you very much for this update!
    Now that I am running with two nail repairs within 7 inches... I may not have as much time as I hoped. As we seem to be averaging about 2,700 miles per month.
    I think I should be okay for another month or so... but don't really want to push them much past that.
    Hopefully either the "Blue Earth 1" or the Defender will pop by then.
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    This is most relevant for Aussie and Asia, I have just replaced my Primacy LCs 195/65/15s after 80,000 kms with michelin xm2s. When I drove away from Bob Jane they felt a little spongy in the corners but they had only put 34 psi in them. They are as quiet as the LCs and grip just as well now that I have pumped them up to 40/40. Just completed my first 4000KMs. They still feel good on the road but economy seems to have declined by .2 l/100kms. This is entirely subjective and I haven't been driving my normal routes.
    I'll update in a few more thousand Kms
  3. AboutTires
    AboutTires New Member
    Boston
    I happen to manage a wheel and tire repair shop as well. As long as the puncture was not too close to the shoulder of the tire, I don't think I would have had a problem making that repair. I think many tire places err way too far on the side of having no liability when it comes to making patch/plug repairs, but taking on that liability is a very personal choice for tire stores. Some will, some won't. I don't think you'll have any kind of immediate problem.
    -Sean
  4. PriusBoom
    PriusBoom Guest
    just installed these new Michelin LRR tires...
    I absolutely love them to death!!! I highly recommend these tires for the Prius.
    MICHELIN PRIMACY MXM4 LRR TIRES 215/45R17
    100% Thumbs Up on these Tires...
  5. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    I bought 4 LRRs from tire rack and my mileage went down, So I went up to 46PSI and it did not help. I am back at 38PSI and I get the same MPG and maybe even better??????????????? These are very stiff tires and I wish I had bought OEMs. Never again.
    195/55R16 Michelin Energy Saver IN STOCK 4 $142.00 $568.00
  6. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Keep in mind your MPGs WILL decrease with new tires until they are broken in. How many miles do you have on them?
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    when I bought Michelen Energy Saver tires, 195x65x15, I noticed
    a 2-3 mpg increase over the Toyota equipped Yokohama Avid
    tires I replaced them with, even though the Avid tires had
    over 10,000 miles and were well broken in.
    I keep all my tires inflated to max sidewall pressure, Energy
    tires are 44 psi, and the Yokos were at the same 44 psi.
    We have over 57,000 miles on the Energy tires now
    and I would expect at least another 10,000 miles of
    tread life left.
    If I can't find Energy Tires when I need new tires
    the Nokian Entyre is my next choice....
  8. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Besides the possibility of improvement after break in (I have never seen good data on that), there is a major factor that causes a drop in APPARENT MPG when tire are replaced. You old tires were worn down which reduced their radius by up to 1/4 of an inch. This changed the calibration of your odometer by about 2*0.25/24 or about 2% (a change in revolutions per mile) which increased the apparent MPG until you put on the new tires when the 2% disappeared.
    Of course, different manufacturer/model tires have different revolutions/mile (even at the same "size") so you need to take that into account as well when comparing your MPG with different tires.
    JeffD
  9. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    674
    179
    Vancouver, WA
    195/55R16 tires are too short with a diameter of 24.4". The proper size should be 205/55R16 which have a diameter of 24.9" vs 25" for the stock 195/65R15 tires. Your mileage will be artificially high since the tire is too small.
  10. ETP
    2,804
    1,170
    Auburdale FL
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Besides tire diameter, you also reduce tread squirm as you wear a tire down. There are a number of reasons why a well worn set of OEM LRR tires may produce better mpg results than a brand new LRR tire but on average, a good set of aftermarket LRR tires are going to perform better and last long than the current OEM offerings.
    ETP, give it some time and see how the numbers work out. Remember to account for weather differences as well. :)
  12. nickinhb
    nickinhb Junior Member
    usa
    Where is the evidence of that statement.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Look at the warranty and tread wear ratings of the various OEM tires offered on the Prius then compare them to LRR tires offered in the same size. For further evidence you can check the "Round and Black" tire test performed by TireRack. While you're at the Tire Rack website look up the customer survey ratings for various OEM tires and compare them to quality LRR tires. You may also want to review all of the anecdotal evidence provided by Prius owners over the years.
  14. Dmanpizza
    Dmanpizza 2010 IV Solar Roof & Navi
    57
    PriusBoom,
    What mpg difference have you seen if any? What tires were you running before? NICE wheels, what are they?
  15. ScottN
    ScottN Junior Member
    40
    Omaha, NE
    I know a lot of people here add more air than Toyota recommends. Keep in mind that LRR tires have worse wet traction (according to Consumer Reports) that non-LRR tires. So, when you put additional air in the tires, you further reduce traction (but improve cornering), so keep that in mind.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is not true across the board. Consider the Primacy MXM4, MXV4 and the ProContact EcoPlus or even the EP100. They offer great wet traction.
    Example:
    http://michelinman.com/tire-selector/name/primacy-mxm4-tires
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    UPDATE
    Introducing the Yokohama AVID Ascend
    An all-season grand touring tire optimized for Long Tread Life, All-Season Performance and Fuel Efficiency. It utilizes Yokohama's Orange Oil technology and earns their BluEarth designation for ecological friendly tires. It appears the Yokohama has created the BluEarth designation for tires in their lineup that exhibit LRR characterstics much like the Green X designation used by Michelin. The Avid Ascend is available in most Prius-oriented sizes except 215/45/17. I'll update the list on the first page ASAP. Approx. cost is $96 for the 185/65/15 and 195/65/15.
    Quick Facts:
    85,000 mile warranty for T rated sizes (treadwear of 800)
    75,000 mile warranty for H rated sizes
    65,000 mile warranty for V rated sizes
    Rolls 11% better than Michelin Hydroedge
    Click to view the Yokohama website: AVID ASCEND Tire Details
    Click to view the Avid Acsend PDF.
    http://yokohama-media.unitedfuture.com.s3.amazonaws.com/1330020056-AVID-Ascend-Bulletin-final.pdf
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Ohh, special thanks to The Critic for texting me about this new tire. LOL
  19. SuperchargedMR2
    674
    179
    Vancouver, WA
    But it is available in a 205/50R17 which is a better choice then the 215/45R17 anyway. The one thing that jumps out at me is how heavy those tires are. :eek:
  20. Hey Dmanpizza,
    They're MOMO Next rims.
