Low Rolling Resistance replacement tyres (Europe)
Discussion in 'Gen 3 Prius Fuel Economy' started by Britprius, Jan 24, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Well done!! Please let us know your impressions of these tyres once fitted.
    John (Britprius)
  2. Dexter1979
    Dexter1979 Junior Member
    17
    Mallow, Ireland
    How are you getting on with these? Tempted to get them but can't find a good price here in Ireland. May have to go for the Hankook's for this time.
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I mounted them yesterday, winter just didn't want to say goodbye it was still snowing on Tuesday. On my way to work it was raining quite heavily at 2°C and I must say the tyres were holding really good, but I didn't exactly try to slide sideways.
    Rolling resistance, I can't really say, I didn't check the tyre pressure yet, I have a feeling that now they are at around 2.2 bar, no more. I will pump them up to 2.7. Hope I will see some results after couple of months driving (will report after summer).
    So far so good, I hope they will hold a little longer than OEM Bridgestone's.
  4. Dexter1979
    17
    Mallow, Ireland
    I should have 4 new Hankook K425 Eco Kinenergy this friday. Will see how they roll.
    Britprius and F8L like this.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Remember that it usually takes a couple thousand miles to see their true colors. They need at least 500 miles to cure.
  6. Ridder
    Ridder Member
    141
    51
    Netherlands
    I have the Hankook K115's.
    Only 400 km's yet.
    FE is better now but higher temps will help too.
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    When I changed over from stock Yokohama Avid tires, 195x65x15, and installed Michelin Energy Saver
    AS tires I noticed an immediate improvement in mpg at least 2-3 mpg more.
    I don't believe there is another tire on earth that rolls better than the Energy Saver AS tire....
  8. Britprius
    5,194
    1,924
    Yes there is, but not available to you yet in the US. The Bridgestone Ecopia 001s.
    John (Britprius)
    F8L likes this.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Aye. The Bridgestone Ecopia EP100 was very very close to the efficiency of the Energy Saver A/S such that errors in the test could have changed the winner. That tire was phased out. 4yrs later I would assume Bridgestone has bested the efficiency of that older tire with the new Ecopia EP001s. I can't wait to see what they come out with for the U.S. market con dieting the EP422 rated poorly by Consumer Reports and most people knock it for poor handling despite good fuel economy and comfort.
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I tried the EP 422 tires. I returned them to Costco during the 30 day money back guarantee period.
    The mpg's were not as good as the Energy Saver AS, also at high speed 65-75 mph I noticed they
    appeared to drift as if there was a side wind hitting the car. I went back to the Energy Saver AS tires for another few bucks more and never looked back....
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Comparing tyres for different markets (and thus different conditions - traffic, warranties, noise pollution, climate) is like comparing chalk and cheese.
    The thread is about European low rolling resistance tyres and the new European tyre rating system.
  12. Ridder
    Ridder Member
    141
    51
    Netherlands
    The Michelin Energy Savers have a B label for FE, like my Hankooks.
    The Ecopia EP100....... I can't find much info on them.....
    The Ecopia EP150 has a C label. But that's a different tire.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Alfon was talking about the Energy Saver A/S. The EU doesn't have a tire like it. The EP100 was also a North American tire only.
    Additionally, as John has observed, sometimes the tires have a different RR rating in different sizes. :)
  14. Britprius
    5,194
    1,924
    Michelin use the "energy saver" name on a range of tyres with varying RR ratings and wet grip. So the energy saver label on it's own does not translate into the lowest RR or best wet grip.
    To be fair non are poorly rated, but to get the best Michelin tyre for the EU market rated B-A (RR-Wet grip) choose carefully.
    John (Britprius)
  15. Ridder
    Ridder Member
    141
    51
    Netherlands
  16. Britprius
    5,194
    1,924
    I run Hankooks myself and find them a very good tyre. I am running the Kinergy Eco 425 also rated BB. I have 18,000 miles on them and at the present rate of ware they look good for at leased 40,000 miles.
    John (Britprius)
  17. Britprius
    5,194
    1,924
    Just updated the tyre list for 195/65/15 tyres with a new Kumho KH27 tyre rated A B at 67db. Ware rate unknown but very good on paper for a budget tyre.
    John (Britprius)
    F8L likes this.
  18. Britprius
    5,194
    1,924
    Just added the new Dunlop Sport Blue Response tyres to the LRR lists in sizes :-
    195/65/15
    195/55/16
    205/55/16
    These tyre are all rated at B for RR and A for wet grip and one of the quietest tyres at 68db.
    Just to reiterate information on price in previous posts. The 205/55/16 size is over £23 cheaper each tyre (25%) than the 195/55/16 in the Dunlop range.
    John (Britprius)
  19. Agape
    Agape Member
    378
    Ireland/Eire
    Thank you for your kind offer.
    I think I will not go for aftermarket wheels for Prii, I will stay with stock wheels.
    Looks like kinergy's are sold out at the place where I was looking at.
    This model is still in stock (I like the pattern)
    Hankook Ventus Prime2 K115 banden
    http://mosautoshina.ru/catalog/tyre/hankook/ventus-prime-2-k115/
    I was bit concerned about the weight of these tyres but considering reviews and spec's it seems to be some tyre for the money...
  20. Britprius
    5,194
    1,924
    Agape, be careful when choosing the Ventus Prime 2 K115 tyre. There is only one size and rating that is BB rated this is the 205/55/16 load rating 94 speed rating W. This is an XL rated tyre, probably ideal for the extra weight of your gas conversion, all the others in 205's or 195's are rated C,E,orF for rolling resistance, and will decrease your fuel economy.
    John (Britprius)
    Agape likes this.
