Low Rolling Resistance replacement tyres (Europe)
Discussion in 'Gen 3 Prius Fuel Economy' started by Britprius, Jan 24, 2013.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Try blackcircles.com
    You won't need a UK reg number to use it. Just enter the tyre size manually and then select Michelin Energy Saver and it'll show the tread pattern applicable.
  2. OzPrius
    OzPrius Junior Member
    43
    New South Wales Australia
    Yep just looked. Our tyres aren't the same as Europe or USA
  3. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Probably not. I'm sure they adjust the tyre formula to match the local temperature and humidity variants.
    A tyre used in -5c to 30c in the UK will have different requirements to 5c to 45c in Australia.
  4. OzPrius
    43
    34.2 in Bradshaw NT / -7.6 in Thredbo NSW. That's today's extremes in Australia. Middle of winter too :)
    GrumpyCabbie likes this.
  5. bp1000
    bp1000 New Member
    Hi John
    How are you finding the hankooks?
    I need to replace my 17" Michelin primacy tyres and I was shocked to see they are rated F for rolling/fuel.
    The prius is very sensitive to conditions and I'm sure tyres are no exception. I see your views are positive in favour of the ventus prime 2 hankooks. How are they doing now? I was curious how the mpg changed if at all from your previous tyres?
    Thanks
  6. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    I ran the Hankook Eco Kinergy tyres to 32,000 miles when I had two ripped to pieces on a piece of steel on the motorway. They would have been good or at leased 40,000 miles without endangering the legal limit. Fuel MPG figure were 5 MPG better than the OEM Turanza's even though I went from 195/55/16 to 205/55/16, and the noise level was way down also. Wet grip was excellent.
    I am now trying out some Goodyear efficient grip tyres with good ratings, but I do not like the handling as much as the Hankooks. Ware life only time will tell.
    The Michelin tyre range is not as low rolling resistance as they tried to have us believe. The new rating system has shown that clearly, and they are expensive.
    The last on your list of three is the same rating as the tyres I was using (B B) so should be a good choice.
    Where are you located "it is not in your avatar" as I may be able to point you in the direction of cheaper prices.
    John (Britprius)
  7. bp1000
    bp1000 New Member
    Thank you John - glad you got on well with them. Looks like my mpg will be flat at the very worst when I change.
    I'm in Stafford - I looked on camskill for the prius tyre size and I didn't see many eco tyres. Like the Eco kinergy you mentioned or the blue energy (I think it was).
    I couldnt see the Michelin energy savers that North American guys like.
    The hankook prime 2 were £68 a think. Thought that was very decent for a 215/45/17
  8. Britprius
    5,194
    1,924
    The Michelin Energy Saver AS is a US tyre and technically is not legal for use in Europe. The tyres in the US are generally not the same as UK/European tyres although the names may be similar. Tyres in the EU must comply with EU regulations and markings.
    Make sure the tyres you order are (B B) rated as different load and speed ratings can vary the rating. I believe the tyre you will use is XL rated to get the rating. The price is in line with a dealer I use in Stourbridge at just under £67 fitted. I am sure you will be happy with the Hankook's, and I would be surprised if you did not see an immediate improvement in MPG improving further as the tyres bed in.
    Please keep me informed whatever you buy with your impressions and economy results so that I can keep the tyre thread updated. It is only with input from PC members that enables a large range of tyres to be assessed.
    John (Britprius)
  9. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    Just a quick one on the Efficient Grip Performance. I'm still happy with the mpgs and the wet grip, but I'm a little concerned with wear. I have approx 15k miles on two if them and they are at about half way. I never let tyres wear right down, so I estimate that I'll have to change at about 25k miles, possibly 30k miles at a push. I do travel all sorts of roads though, crappy city roads as well as country roads and some motorway. I've kept the pressure between 38 and 42, trying different pressures vs comfort.
    They cost me €90 each fitted and are great with regard to mpgs and have very very good wet grip (tested recently in some extreme showers at motorway speed).
    I might have to compromise on wear to get the other benefits.
  10. Britprius
    5,194
    1,924
    Thanks for the information Tony. I am running a version of the Efficiency Grip tyres, but not the Performance. I feel these will also not last as well as the Hankook's, although the ride is a little softer. The Hankook's felt more stable on the road. Not enough miles on them to tell yet however.
    I change my tyres round when the fronts get to about half worn. Usually at this time the rears show little sign of ware so changing them gives a fairly even life. This flies in the face of convention that says the best tyres should always be on the rear, but if that were the case one could never change the tyres round as the fronts always ware faster.
    John (Britprius)
  11. Tony D
    469
    132
    Dublin, Ireland
    I'm the same, good tyres to the front, worn to the rear. I just bought 2 new ones for the front and stuck the half worn on the rear. I had a pair of crappy Chinese 195s on the rear and after 15k miles, they are still like new! Thanks to Arnold Clarke for fitting them the day i bought it. I'm a tyre snob so they had to go! I was never happy with them anyway and felt the back end was a little twitchy in the wet, plus the 205s look much better on the rear, the 195s are too skinny looking, with the offset looking all wrong as a result
    I think that I might try a pair of Dunlop Sport Blue Response next out of curiosity. There is actually a nice selection of good brand LRR tyres in the 205s, I'm glad I changed from the oddball 195 size.
  12. bp1000
    bp1000 New Member
    I would like to chip in here about worn rears.
    I was in a rented hire car with very worn rears and the driver was doing marginally over the limit on the m6 toll. A sudden down pour left standing water and on a slight bend the rear end just went. The result was 4 spin impacts into the central reservation and a written off hire car.
    Lesson here is always check hire car tyres. Also don't underestimate the rear tyres job which is ultimately to keep you pinned to the road, once they let go there isn't much hope of recovery. With the fronts at least they under/oversteer.
    Of course half worn is completely safe! But don't let them get too low.
    Tony D likes this.
  13. Britprius
    5,194
    1,924
    Yes there is a much greater selection of tyres at 205 section. The prices are also much better. I have had some good reports on the Dunlop Blue Response, but no feedback yet on how well they last millage wise. If I get any more details I will post it.
    One other great thing about the 205's is they do protect the wheel trims from kerbing. With 195's no matter how lightly you touch a kerb you end up with gouges on the trims.
    John (Britprius)
    Tony D likes this.
  14. Britprius
    5,194
    1,924
    As a driver that did 55,000 miles a year company millage when I was working "before retiring" I know the importance of good tyre tread depth and change my tyres at 3mm. Some say that I am wasting money, but on many occasions I am sure good tyre tread depth has saved me from a collision. Stopping distance greatly increase when tread gets below that level.
    You were lucky you were on the M6 toll with little other traffic possibly the only road in the UK I have never been on. Both the company I worked for along with myself would not pay on principle to use it.
    John (Britprius)
  15. Tony D
    469
    132
    Dublin, Ireland
    I'm the same, I never let the tyre get down to the legal minimum. I too find that once it gets down to the minimum legal depth of 1.6mm here in Ireland. 1.6mm in my opinion is bald and dangerous.
    Yes I might be wasting my money changing early, but I think that it's cheaper to replace a tyre than to be in an accident cause I was too tight to change a tyre!
  16. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Sensible advice.
    The way I look at it is that a whole set of branded tyres is about £280. How much is the excess on your insurance? £150? £250? Changing tyres is good insurance as it stops you getting into a smash or ending up on your side in a ditch or parked on top of a hedge, especially considering how wet our weather is. And if you just need to change the fronts then it's only £140 for two.
    Tony D likes this.
  17. bwilson4web
    16,552
    I'm looking at a Nokian 185/70/14 W+ to use on our 2003 Prius in North Alabama. Unfortunately, we really don't have many outlets selling Nokians in the USA. Worse, their web site is pretty lame about technical information for this tire. So my questions are:
    • Is there a Web site with technical information about the Nokian W+?
    • What is their general reputation?
    • It looks like they are really after winter tire sales including studded . . . any problems in warm weather, 40C?
    I have another alternative but wanted to throughly investigate this model tyre first.
    Thanks,
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Try the following UK link. It might help a little.
    Nokian tyres: Order best quality here | mytyres.co.uk
    Enter the tyre size for your car (you don't need a UK reg number that way) and it should bring up a list of all the available UK Nokian tyres, giving their economy, wet grip rating, noise level and importantly owner reviews. Now whether they're ok in 40c heat is another matter. I thought the Nokian tyres sold here were for northern Europe and some of the model types probably won't be available for you. But it gives an idea of what they're like.
    #138 GrumpyCabbie, Aug 22, 2014
  19. bwilson4web
    16,552
    Thanks!
    I like the EU rating system for tyres. The web site is pretty good too.
    I remain amazed at how hard the tyre/tire vendors work to obscure their tire performance specs.
  20. Tony D
    469
    132
    Dublin, Ireland
    They are regarded very highly in Nordic Countries, Norway, Sweden, Finland, Denmark etc.
    They're not a huge seller here in Ireland as we don't get huge snowfall here and people here don't really see the point of winter tyres . . . .
    Try this link too for more info
    Nokian W+ 185/70 R14 88T - eiretyres.com
