Low Roof line on the Gen 5 Prius
Discussion in 'Gen 5 Prius Main Forum' started by Marvinh, Feb 22, 2025.
  1. Blackat
    Blackat Active Member
    458
    319
    Colorado
    2023 Prius
    Limited AWD-e
    5-11. I've never hit my head or had to contort to get out.
    Weird.
    I have absolutely no issues with any control placement or anything with the car.
    Perfect car for me.
    YMMV obviously
  2. Winston Smith
    Winston Smith Active Member
    358
    241
    OH
    2024 Prius
    LE AWD-e
    Some of this will be age and flexibility related. I'm 6'2", and have folded myself into lots of awkward little cars when I was younger. How I get into and out of a Prius now takes into account some knee and back injuries.
    A manufacturer is only going to do so much for the thin ends of the bell curve. I believe there is a range of cheap shoe manufacturers that don't even make size 13 shoes. I've never seen a size 13 shoe at Costco. Some lines of trousers don't come in a 34 inch waist and 34 inch inseam. These companies aren't losing much just because I don't buy from them.
    The same rationale should work for cars. If you are professional basketball tall, you weren't going to look for a Prius anyway.
    #22 Winston Smith, Feb 24, 2025
    Gokhan and RPO 579C like this.
  3. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    I'm about the same size as you and in my 50's. The lower roof line takes a bit of getting used to. It is definitely more difficult to enter. I don't recommend this vehicle to people with mobility issues. However, it is a VERY fun car to drive. I drives better than the 6 cylinder convertible Mustang that we used to own.
    Gokhan likes this.
  4. TheGodX
    TheGodX New Member
    Austin
    2024 Prius
    "drives better than V6 Mustang" - in what sense?
  5. Prodigyplace
    12,548
    11,772
    Central Virginia
    Ride comfort & fuel economy? Just a guess...
  6. Trollbait
    12,520
    Guessing they also had a Mustang from before the switch to independent suspension; a solid live axle in the rear like a truck.
    Prodigyplace likes this.
  7. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Same here more than happy! my local dealer now has three of these in stock. I think the problem was people didn’t have a chance to sit in it before they buy, I waited eight months to get my 23 one of the first to order! just by looking at it, you can see it has a low roof sports car coop look almost! It’s not for everybody but fits me like a glove
    Blackat likes this.
  8. Prodigyplace
    12,548
    11,772
    Central Virginia
    do not know. the only Mustang I owned was a 1970, one of the last big ones before the Mustang II.
  9. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    5th gen Mustang(2004-14) with the V6 had about the same power and performance as a 5th gen Prius.
    Mustang V6 - 210hp, 240ft-lb, 0-60 in around 7.3sec, 3300lbs gross weight
    Prius HEV FWD - 194hp, 139ft-lb*, 0-60 in around 7.1sec, 3100lbs
    Prius PHEV - 220hp, 139ft-lb*, 0-60 in around 6.6sec, 3500lbs
    *torque isn't really comparable between a hybrid and an ICE-only, but I included it anyway
  10. cool_prius
    cool_prius Member
    106
    36
    United States
    2025 Prius
    I'm 6' tall and coming from a sporty car. Used to it. Also used to resting my knees where the dash and console meet and having my legs bent at a specifically tight angle. This is something you can get used to over time for sure. Not banging your head, but clearing the door without hitting it. It's just muscle memory.
    #30 cool_prius, Mar 2, 2025
  11. Winston Smith
    358
    241
    OH
    2024 Prius
    LE AWD-e
    Just guessing - in every way?
    j/k
    #31 Winston Smith, Mar 3, 2025
  12. Prodigyplace
    12,548
    11,772
    Central Virginia
    Just guessing again I doubt it was more economical, just for starters. Many people buy cars as efficient transportation.
  13. RogerPriusTX
    RogerPriusTX Junior Member
    57
    Dallas, TX
    2024 Prius
    I have to bend quite a bit to get in and out of my 2024 Prius -- I thought it was due to the glass roof (I'm just under 6')
    I have also accidentally turned on the turn signal when getting out/in.
    If I'm not careful how I reach over the center area, I have accidentally engaged EV mode and also turned traction support off.
    While I generally like the car, some of the changes don't seem to have been well thought-out.
  14. Prodigyplace
    12,548
    11,772
    Central Virginia
    FWIW, my 2025 Camry XLE with seat memory automatically moves the drivers seat back to make entry & exit easier.
    Jotunn likes this.
  15. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    I don't have seat memory, but I do have it all the way down. It looks like it will go back quite a ways, so I may try that to see if it helps.
  16. Jotunn
    Jotunn New Member
    17
    High Point, NC
    2024 Prius Prime
    XSE Premium
    Prime XSE does this as well, zero issues getting in and out of the Prius or 2025 Camry XSE. The low roofline thing is way overblown in my opinion. 6'0", 225LBS for reference.
  17. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Well, maybe I'm just too fat?!
  18. bisco
    51,896
    Does the us xle version get memory seats?
    Our 24 didn’t :(
  19. Prodigyplace
    12,548
    11,772
    Central Virginia
    Yup and all 2025 Camry are Hybrid., FWD or AWD. In my car, Drivers Seat & outer mirror memory were part of the Premium Plus package that also added panoramic moon roof, panoramic view monitor, and other safety features.
  20. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's easier to get memory seats on the Prius than the Camry.
    The Prius Limited and Prius PHV XSE Premium come with memory seats as standard. Memory seats are only available on the XLE Camry as an option. They are not available on any of the other trims(LE, SE & XSE).
    bisco and Prodigyplace like this.
