Low speed brake "grind"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johnstecz, Jun 3, 2022.
  1. dolj
    dolj Senior Member
    8,648
    4,399
    Wellington, New Zealand
    Thanks for sharing that info, I've seen that product mentioned here and there in brake grease discussions.
    I see it comes in a box of 1,000 5 g sachets or a 20 kg pail. I wonder how much they charge for a box? It seems like Molykote is not represented here in NZ, I'd have to order from Australia if I was at all interested to buy some. Not on my list of priorities at the moment, even assuming pricing was a lot cheaper than Toyota's
  2. Johnstecz
    Johnstecz New Member
    Bertram, TX
    I got the codes:
    C1256, c1391, c2318
    I need to try and do intake valve cleaner spray technique to get rid of the code for the catalyst, but the other two are the typical brake modulator errors.
