Low temp shudder on tight radius turns?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by M. David, Feb 18, 2015.
  1. M. David
    M. David Junior Member
    North Central USA
    Three Touring
    I'm new to the 2G and wondering if anyone has noticed a wheel shudder or jump when turning a tight circle in low temps? I'll try to list out all the info I can:
    The shudder was exactly like a 4x4 vehicle in low range/diff-lock when turning on dry pavement.
    Going straight or slight turns only, nothing noticeable. ( I was paying attention)
    200k miles, just bought the car and haven't changed the WS atf yet.
    Temps in the -25°C/-10°F range [lucky me]
    Anyone have a similar experience?
    #1 M. David, Feb 18, 2015
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Check the front CV boots for cracking / leakage. Wouldn't surprise me at all if they need replacement (10 years old and 200K miles). Even if only one needs it, might at well replace them both since the difference in labor isn't that much.
    52,803
    dry road?
  4. M. David
    North Central USA
    Three Touring
    Yep it's cold, but pavement is dry.
  5. M. David
    North Central USA
    Three Touring
    Thanks that does make sense. any recommends on brand for new axles? I have used auto parts-store type brands (most seem to be rebuilt in China) on other cars, most recent spent the cash on Raxles for a Subaru.
  6. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    I have no brand preference. I've only had to do it once on a different car. With a 10 year old car and 200K miles, I'd just buy whatever is cheapest and assume that it will last longer than the car itself.
