Low Tire Pressure Warning Light is ON? I have Good tire pressure in all tires? What's Wrong?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ski.dive, Jul 12, 2015.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    OK,
    I also tried to RESET the warning light according to the owners manual instructions and the warning light will not reset???
    #1 ski.dive, Jul 12, 2015
    51,950
    i don't think it determines which tyre, maybe tech stream? what pressures are you running, cold?
  3. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    You have a 2008 Prius. It's about right that the TPMS give you warning. Probably the TPMS is at end of life. You probably have to replace all of them. Don't think you can buy a battery and put it in. TPMS warning light isn't a big issue. It still let you pass smog.
    51,950
    never heard of tpms end of life reports here before.
  5. apt5020
    881
    1,294
    Prius City, CA
    ftl likes this.
  6. bisco
    51,950
    wasn't doubting you, just don't understand why this doesn't come up more often.
  7. Mendel Leisk
    41,464
    ^ Since TPMS was mandated in 2007 model year (according to APT5020's link), maybe this is just starting to be an issue.
    I'm just glad it's not compulsory in Canada. And there are systems that avoid costly sensors in individual tires, rely on variations in tire revolutions as they deflate?
  8. bisco
    51,950
    good point, it will be interesting if this is the first of many. if that's the case, there will be an explosion in complaints, as they are not cheap?
  9. ski.dive
    964
    244
    As we all know, the TPMS SENSORS for the tires are very expensive!!!
    Is there a way to ELIMINATE the TPMS $ warning light, so that I can put on old fashion regular tire valves on my tires?
  10. bisco
    51,950
    electrical tape?
    Merkey and ftl like this.
  11. kpang
    kpang New Member
    Try this. Deflate all tires and fill the air again to the correct amount. Sometimes this will reset the TPMS.
    Also, sometimes you need to drive it for few minutes and the warning will go off.
    #11 kpang, Jul 12, 2015
  12. Mendel Leisk
    41,464
    It's one little light, less intrusive than the passenger seat air bag status. You forget it's there after a while, with snow tire sans sensors.
    Merkey likes this.
  13. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    double check the pressure in your spare tire
  14. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I don't believe there is a TPMS sender on the spare tire.
  15. bisco
    51,950
    i wish there was, but it would have to be specific. i wouldn't want to have to pull the dang thing out, only to find it was another one.
  16. apt5020
    881
    1,294
    Prius City, CA
    Spare don't have TPMS unless it is a full size spare like the RAV4
  17. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    since our govt here in the USA is a pack of worthless retards, they decided we had to have an active system, even though using the wheel speed sensors which were already on the car would have worked just fine. I really wish the towel heads had flown a plane into the capitol building instead of killing a bunch of innocent new Yorkers, and hardworking pentagon employees. they would have done us all a big favor.
    most likely one or more of the batteries which are molded into the sensors, has gone bad. a tpms tester, which most shops have now, can read the battery life of the sensors.
  18. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ...my TPMS is acting up now at 9.5 years old...
  19. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I had to replace one several years ago, and got another 2 when I bought 2 new tires. One original 2006 left...
    wjtracy likes this.
  20. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    I remember when the tpms were first discussed Bosch mentioned an 8 yr life. Some should be failing now.
    iPhone ?
    wjtracy likes this.
