Low Voltage in Rear Power Outlet
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, Nov 27, 2018.
  1. ChapmanF
    19,008
    Anybody done the same check on a different Prime yet?
  2. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Not that I know of. I pretty much gave up once I learned Toyota's specs allow the DC-to-DC converter to output as little as 11V. In that situation with the wiring they have, trying to draw 10A from an outlet would drop the voltage below 8V. It would literally be impossible to draw the allowed 120W from an outlet with the current setup.
    I have a family member a few hundred miles away that recently bought a Prime, but that's the only one I might have access to for testing.
  3. PiPLosAngeles
    1,551
    724
    Can somebody here bring up their Prime's diagnostic screen and see if they also see a 12.6V reading in drive?
  4. PiPLosAngeles
    1,551
    724
    Well, Toyota regional contacted me about my arbitration case and asked if they could send a Field Technical Specialist to inspect the car. It's at the dealership now. We'll see what they say, but I'm not holding my breath.
  5. PiPLosAngeles
    1,551
    724
    They finished looking and see the voltage drop I see and claim that the vehicle is operating as designed. The voltage loss is by design and with regard to the owner's manual stating that the 12v outlets are rated to 120W: "the manual does not say they will supply up to 120W in drive, and since they will do so while in park there is no defect."
  6. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    The 2016 prius and later have two modes of inverter operation. I'm not sure if 12.6V indicates constant voltage mode but it's probably worth looking into.
    note: the above is quoted from Please explain 12V system to me--how to keep battery charged while using accessories? | PriusChat
  7. PiPLosAngeles
    1,551
    724
    Thank you for that info. The flaw in Toyota's logic is that the ECU is measuring the voltage at the ECU without accounting for losses due to the tiny wires Toyota uses. So, sure, it's 12.5V at the ECU, but at the outlet someone trying to charge their laptop at 80W will find something more long the lines of 9.8V. And, as is my case, they'll find their equipment inoperable. Whoever designed the drop-down to 12.5V in drive made a gross engineering error. It is speculation on my part, but I suspect the guys designing the wiring harness were assuming 13.8v - 14.0v and the guys designing the DC-DC converter operation were assuming wiring designed for 12v.
    The weirdest part of all of this to me is that reducing the voltage of the DC-DC converter output decreases efficiency, not increase. Why would they intentionally decrease the efficiency of the 12v system?
  8. PiPLosAngeles
    1,551
    724
    For those interested.
    kevin.c likes this.
  9. ChapmanF
    19,008
    You're talking about a voltage drop of 2.7 volts at 9 or 10 amps. That would require a total resistance, between the measurement point at the ECU and where you measure at the power outlet, of 0.27 to 0.3 Ω.
    I'm not sure of the actual gauge of wire Toyota uses in that circuit. 0.27 Ω would be 42 feet of 18 AWG, 34 feet of 19 AWG, 27 feet of 20 AWG, 17 feet of 22 AWG. I don't know that they've got that much wire bundled up in there (it's funny, they did build a long bundle of coiled-up wire on purpose for the early Gen 3 headlight fix, when they wanted to drop voltage. Let's see, if I'm right about that bundle being 55 cm long and having five loops inside, that's 5.5 m of wire adding up to 0.12 Ω, which would be about right for something between 18 and 19 AWG; I suppose it's a metric size really).
    Of course, there are also some connectors on the path, and at least one 15 A fuse. I've just measured a 15 amp ATM fuse at 0.00468 Ω, so it doesn't look like a big piece of the puzzle. It rises to 0.00557 Ω over several minutes at 10 amps, as the fuse heats up.
    Where do you suspect the lion's share of your voltage drop is happening?
    kevin.c likes this.
  10. PiPLosAngeles
    1,551
    724
    I don't know, but we know for certain it is happening somewhere between the fuse and the wire connection to the back of the outlet. The voltage at the fuse is only like 0.05v less than battery voltage. At the outlet connector we see about 1.6v drop running a 60 watt light bulb. The inverter claims >90% efficiency, so worst case we're drawing about 6 amps. 1.6/6 = 0.267 Ω I don't know how thick the insulation is, so I'm not certain what actual gauge of wire is in there, but they don't look much different than what you'd pull out of a twisted pair in CAT6.
    EDIT - 17 feet of wire wouldn't be much when you consider that it's the total length of wire, meaning all the way from the fusebox to the load and back to ground.
  11. ChapmanF
    19,008
    I'm still thinking 0.267 Ω is quite a lot to try to explain away just by guessing at how small the wire is. There can't be too many connectors on that path, maybe one of the connections is lousy. I would at least check; could be an easy fix.
    They do use freaky thin insulation ... I don't know what that stuff is, but it sure saves them a lot of wire-harness bulk.
    The return path to ground is usually to the nearest harness ground point (and thence through the car body, whose resistance we can take to be really, really low). I don't know where the nearest ground point is to that location, but the wiring diagram shows them all.
  12. PiPLosAngeles
    1,551
    724
    Could be, but it would have to be something that is common to both outlets and to the other Primes the tech tested.
  13. ChapmanF
    19,008
    Common to both outlets makes the wire-length explanation seem weirder to me; I'd assume those lengths are different.
    On the other hand, common to both outlets probably reduces the number of possible lousy connections to check.
  14. PiPLosAngeles
    1,551
    724
    The voltage drop is slightly different between the outlets, but not by much. IIRC, about 0.3v. They are separate circuits, so they can't be sharing any connections.
    #134 PiPLosAngeles, Mar 1, 2019
  15. padroo
    padroo Senior Member
    2,763
    2,253
    The best connection you can get is a separate circuit fused right off of the battery. The big part of that would be getting through the firewall.
  16. Elektroingenieur
    2,515
    3,288
    Three Touring
    I imagine Toyota’s actual wire specifications are proprietary, especially now that they’ve become a subject of litigation, but Sumitomo Wiring Systems Ltd. and Yazaki Corp., two leading wire harness suppliers in Japan, have catalogs of their stock wire and cable products that may be of interest.
    Yazaki’s catalog is in Japanese only, but SWS’s catalog is also published in English, so I’ll use it as an example. They have traditional AV (Automotive Vinyl) wire, but also several styles with reduced overall diameters. The conductor resistance doesn’t change much; compare the following, all at 1.25 mm² nominal size:
    Type Overall Diameter Insulation Thickness Maximum Conductor Resistance (20 °C)
    1 AV 2.7 mm 0.6 mm 14.3 mΩ/m
    2 AVS 2.5 mm 0.5 mm 14.3 mΩ/m
    3 AVSS 2.1 mm 0.3 mm 14.9 mΩ/m
    4 CAVUS 1.8 mm 0.2 mm 14.3 mΩ/m
  17. ChapmanF
    19,008
    Hmm ... 1.25 mm² would fall somewhere between AWG 16 and 17, and at 14.3 mΩ/m you'd need just under 18 meters of the stuff to account for a 0.27Ω resistance ... about 62 feet ....
    Edit: ok, I see that's the largest area offered in CAVUS in the catalog, so it's possible something thinner has been used. Anything below 0.50 would show insufficient ampacity in their chart even at 20 C, so I imagine that's about as small as it might get. Looks like that would still take about 30 feet.
    #137 ChapmanF, Mar 2, 2019
