Low voltage to traction battery relays. (11.2) , inverter pump doesn't run
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tallman, Jan 18, 2020.
  1. tallman
    tallman Junior Member
    60
    wv
    Only thing amiss that i can see is security light blinks all the time unless fob is inserted, remote does all that it should as far as locks and etc
  2. tallman
    60
    wv
    The inverter pump was unplugged at the pump itself, I plugged it back in and seemed to here something running inside, not at the pump itself, the single wire at the fuse box turns off the house also.
  3. tallman
    60
    wv
    Researched the security light and it is normal, just can't get to ready mode.
    51,902
    sounds like a bad 12v.
  5. tallman
    60
    wv
    12 volt Checks ok , hooked another 12 volt to it, 12 volt traction relays are not kicking in, have voltage coming to the power plug to them but when u connect the little white plug it seems to lose all voltage, do traction battery relays get power from a relay or a switch,thinking maybe a weak relay up front, but I haven't found it
  6. tallman
    60
    wv
    Verified inverter pump is running
  7. bisco
    51,902
    power button opens circuit to relays, but ecu's need correct voltage. going back through this whole thread, i cannot find it.
  8. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    Going back to your post #5, what voltage are you getting at the front jump points after the car has been sitting overnight with the hood open (so you don't have to open any of the doors and affect the voltage that way)? If you are not getting something like 12.5V or better under those conditions at the jump point, either your 12V battery is bad or, as you suggested, the cable going from the battery in the back to the front jump point may be damaged and shorting out against the car body.
  9. bisco
    51,902
    vermin?
    davecook89t likes this.
  10. tallman
    60
    wv
    Checked today I had 12.4 at back 11.9 at front jump point, I did hook a jump box at the front and was getting 12.5 , but still no ready light
  11. bisco
    51,902
    yep, either a bad connection in back, or a short on the way to the front
    tallman likes this.
  12. tallman
    60
    wv
    Thinking of running a cable from rear battery to the jump point and see what the difference is
  13. davecook89t
    1,089
    825
    Four Touring
    Getting a good charge at the front jump points, if it comes from a source other than the 12V battery in the back may not be sufficient, I'm not sure. FYI, at one point when going on vacation, I disconnected the negative 12V cable in the back to save the battery from dying and a couple of weeks later was able to get the car doors to unlock by hooking a jump box to the terminals in the front, allowing me to avoid crawling through the back seat to open the hatch from the inside. That is not the same as getting the car into Ready mode, however. I'm thinking that I wouldn't be able to get the car into Ready mode with the 12V battery disconnected, which might be similar to your situation if you have a bad cable.
    If you are getting all the lights on the dash when you press the Power button, another possibility may be that the sensor that detects whether the brake pedal is depressed may be defective. Maybe it is not allowing the 12V to send a signal to close the contacts and engage the HV battery (but possibly it could still go to Ready mode, but just not have any power to start the ICE, again I'm not sure). Do you hear a click coming from the back when you put your foot on the brake and press the Power button, indicating that the HV battery is connecting?
  14. tallman
    60
    wv
    No click , relays are not closeing
  15. davecook89t
    1,089
    825
    Four Touring
    Ok, so we have not yet eliminated that brake sensor as the source of the problem, if there is no click. Looking through the repair manual, I see a component listed as a Brake Pedal Stroke Sensor and also a Stop Light Switch. I'm guessing the Stop Light Switch would be like any you would find on a non-hybrid car, so it would probably not prevent the car from going to Ready mode if it had failed, but just out of curiosity, do your brake lights come on when you step on the brake?
    So I'm focusing on the Brake Pedal Stroke Sensor and am attaching 2 pages from the manual for troubleshooting that component. On the other hand, if that has failed you should get a C1247 code and a C1393, and all the codes you reported relate to the Inverter, I believe. Is it possible your scanner is not picking up codes from the Skid Control ECU, which would throw the C1247 and the C1393?
    Maybe I'm leading you down a garden path, and the problem is the Inverter all along. I'm not sure if a failed Inverter prevents you from getting to Ready mode. I'm guessing it would, but maybe someone else can weigh in on that question.
  16. davecook89t
    1,089
    825
    Four Touring
    I should have included these pages as well.
  17. tallman
    60
    wv
    Checked early on I do have brake light , I checked for power at wires going to relays( white plug with three wires )all three have power with it unplugged coming front , with button pushed , when I plug it back to the hv battery side , I seem to lose power. Like when u put a load on it , it breaks circuit, the best I can get at the three conductor plug is about 11.7 volts,. This may the wrong thing to do but I ran 12.4 volts to the relays from the back battery and they close
  18. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Did you happen to have a chance to read/follow along with @TMR-JWAP in post #16 above, and what were the results?
    Curious about the mileage and condition of the vehicle, has it ever been in a wreck?
    You really a mini-vci cable w/techstream, or an OBD2 reader that can offer up the stored INFs (detail codes or subcodes).
  19. tallman
    60
    wv
    Yes fuse link is good, useing a snap on ultra scanner , 2007 146 k a man from NC drove to Canada and was on his way back to NC , it quit on him, he had it towed to a Toyota dealer they did analysis told him it likely needed a new wireing harness because they found rodent dropping s in it , wanted $5000 to replace he sold it too me I research per VIN on Toyota site, most notable thing was inverter pump replace 20 k ago
  20. bisco
    51,902
    ah, that's gonna be some work
