Low voltage to traction battery relays. (11.2) , inverter pump doesn't run
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tallman, Jan 18, 2020.
  1. tallman
    tallman Junior Member
    60
    wv
    They couldn't verify any damage , just said they saw droppings
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Don't know anything about that scanner, maybe someone else does and can chime in.
    See if that "snap-on ultra scanner" has the secondary codes (INFs), as a bunch of your listed DTCs have related INFs.
    tallman likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    I'll mention it again
    A 10.5 amp continuous draw from the 12v system is not normal. That completely explains why there is 12.x at the battery terminals, but not at the rest of the system. Try removing the ABS relays in the underhood fusebox and see if that draw goes away.
    tallman and davecook89t like this.
  4. tallman
    60
    wv
    Appreciating you guys help with this
  5. tallman
    60
    wv
  6. tallman
    60
    wv
    Don't think I mentioned this Toyota shop that checked this out left the inverter pump unplugged at the pump, I plugged it in it makes a noise like it's running but no action in the resivoir
  7. bisco
    51,902
    hmm, sounds okay then
  8. tallman
    60
    wv
    Getting close to the problem I think, I have power going to the hv battery s relays with a volmeter 11.96 with button pushed, when I touch a test light to the same place I'm getting the 11.96 it drops to about 1.9 volts, does this power come from a relay or switch up front? , I did run another ground from the battery ground , no change
  9. bisco
    51,902
    Not sure, I don’t have a schematic handy
    tallman likes this.
  10. tallman
    60
    wv
  11. bisco
    51,902
    those can be looked up and troubleshot in the service manual
  12. dolj
    dolj Senior Member
    8,445
    4,289
    Wellington, New Zealand
    The P0A0D tells you you have not installed the safety interlock correctly, or the wire that goes from the switch at the bottom of the interlock is not connected.
    SFO likes this.
  13. tallman
    60
    wv
    Checked interlock visual and with ohm meter, it's good
  14. tallman
    60
    wv
    Probably going to take apart interior and look for rodent damage , Toyota shop said they found rodent droppings
    SFO likes this.
  15. bisco
    51,902
    that sounds like a good idea. where's the main wiring harness, inside or out?
  16. dolj
    dolj Senior Member
    8,445
    4,289
    It doesn't mean the plug is bad, it is not inserted correctly. Did you do all three steps as per the diagram in post #52? If so, the car does not detect it and warrants further investigation.
    SFO likes this.
  17. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    There is a wire connector just to the rear of the HV Battery cooling fan that frequently has significant corrosion issues. If you remove the passenger side trunk trim panel to expose the cooling fan, I'm sure you'll see the connector I'm talking about. I've removed the connector in a couple cars and just spliced the wires to their counterparts. The connector in the below photos was one of the better ones I've seen.
    SFO likes this.
  18. tallman
    60
    wv
    Looks to be under the plastic inside
  19. tallman
    60
    wv
    Yes did all three, and then took small white connector apart and checked for continuity from Safety switch it checked good so trouble may be farther forward
  20. tallman
    60
    wv
    Also will take other side apart check connection s and clean fan
