Low windshield washer fluid warning/light?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by ricomtl, Feb 15, 2019.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I'm upgrading from Prius V to Prime in a few days and wondered if Toyota has finally implemented a low windshield washer fluid light/warning in the dashboard?
    I've read the user manual and didn't see anything.
    Has anyone seen such a warning light?
    Thanks!
  2. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Nop! No improvement in that area from Gen3 to Prime (Gen4 included).
  3. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Seriously!? .... *sigh*...
    Salamander_King likes this.
  4. Salamander_King
    10,970
    8,853
    New England
    I always carry a gallon bottle of washer fluid, just in case I miss catching when it's getting low.
  5. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I know, I always have one as a back-up. Low end models have this built-in warning light! With all the bells & whistles already built-in in this car, can't believe they forgot this one!
  6. Salamander_King
    10,970
    8,853
    New England
    Yap, one more sensor and a small indicator are all needed. I don't know what drives their decision on inclusion and exclusion. I would much rather have the low washer fluid warning light on my dash than having the useless nav system, IMHO.
    #6 Salamander_King, Feb 15, 2019
    ricomtl likes this.
  7. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i cant recall, but i just filled a few of my cars including the brand new prime (of course not filled at the dealer) i think the prime has a yellow dipstick in the wiper fluid bottle !! lol
    old skool;)
    ricomtl likes this.
  8. Tideland Prius
    16,128
    My Prime doesn’t have a dipstick in the washer fluid bottle so I thought they finally implemented the light.
    ricomtl likes this.
  9. bisco
    49,401
    our hycam doesn't have either either. i wonder if the new model got it.
  10. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    i normally just fill when it gets empty. am i a barbarian ? :)
    jerrymildred, Old Bear and fuzzy1 like this.
  11. bisco
    49,401
    what choice have we?
    ricomtl likes this.
  12. fuzzy1
    10,166
    You could fill up preemptively after certain intervals of heavy use, as I have been doing. Added 1.5 quarts to my Suby once last month, more often closer to a pint when checking other things under the hood.
  13. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I check my cars every week and top off the washer fluid then. I check the oil and look at coolant and brake fluid. I know it sounds a little obsessive but until recently my wife had a long commute on back roads to work. I may switch to every two weeks or monthly now.
  14. Mendel Leisk
    38,668
    Maybe they owe you one, from the 2017 North American Prime Owner's Manual:
  15. bisco
    49,401
    i fill mine after trying to use it to clean a windscreen i can't see through
  16. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    When you buy gas, don't those nice uniformed service station attendants top off your washer fluid for you when they're checking the oil? They usually check the air pressure in each tire, make sure the radiator level is full, and add water to the battery if needed, too.
    I guess Prime owners must run out of washer fluid because they put gas in their cars so rarely.
    walterm, RobH and Marine Ray like this.
  17. Mendel Leisk
    38,668
    But I want the cute pink stuff Yota sells.
  18. Salamander_King
    10,970
    8,853
    New England
    I want Yota fluid that's good to -40F/C. The lowest temp I could find locally was this one from Rain-X, but it's only good to -30F.:cry:
  19. Mendel Leisk
    38,668
    Fwiw the -40 rating doesn't stop it freezing just below 0C, in some conditions. Not sure how much those ratings mean.
  20. Salamander_King
    10,970
    8,853
    New England
    Really? I used -20F rated fluid before and it froze on the windshield in winter morning when temp was around 0F, but with this -30F rated fluid last few times I used in the cold morning down to 4F, it did not freeze. We have not had a severe cold this winter, but it's nice to have washer fluid I can use in the cold morning without warring freezing onto the glass.
