Lower body moldings
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by nhguy78, Nov 14, 2012.
  1. nhguy78
    nhguy78 whirr...........
    51
    Hudson, NH
    I really like the lower body door moldings. I don't see it as available for PIP. Is it possible to get it installed even though I don't see it listed? Has anyone else done this?
  2. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    I just order PIP ones from the prius chat store..
  3. nhguy78
    51
    Hudson, NH
    Oooh, ok. It will be a week or so before I even take ownership of my PIP. I'm really liking the color contrast with the blizzard pearl, sea glass, clearwater and winter gray.
  4. lensovet
    2,615
    496
    Burlington, NJ
    Any Toyota dealer's parts department should also be able to order these for you.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    If you look at the PIP in the Hum commercial, it has the moldings on it.
  6. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Those can be ordered and applied at PORT. (Thanks, Dianne W. !) So it's probable that some Pips on the lot already have them. The "Plug-in Prius" moulding was also available through Prius Chat store and through Toyota Parts Dept.
  7. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    They do look really good. But, I already have a lot going on the side with body side moldings to prevent door dings and the European splash guards. Otherwise I would get these to accent the car. It matches well with the silver on the door handles and rear hatch.
  8. innerpri
    innerpri Junior Member
    55
    MD
    Is it peel and stick?
  9. lensovet
    2,615
    496
    Burlington, NJ
    Yes. Someone had a video posted; just search the forums.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    Here you go.
    lensovet likes this.
  11. nhguy78
    51
    Hudson, NH
