Lower control arm bolt stuck
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fifen, Jul 15, 2023.
  1. Fifen
    Fifen Member
    77
    33
    Utah
    I was attempting to replace my suspension on my car today. Lifted the engine removed the passengers side control arm with minor difficulties. Installed new control arm and ball joint. Then the drivers side. But the lower control arm bolt closest to the front would not come out. I got it about millimeter out but then it was stuck. It would spin a bit while making clicking noises while being spun. I tried numatic air gun (didn't work). Tried penetration oil (didn't work). Used a blow torch (didn't work). My friend got it to come out by about a millimeter but then couldn't get it further. We couldn't get it back in either. Can't cut it either cause it's inside a frame piece so cutting it would only make it more stuck. The bolt goes through the bushing into the frame. There is not access to the nut.
    Does anyone have any idea or tips. I think I'll have to tow it to a shop. Anyone have a clue how much I should expect to pay for them to get that bolt out?
    Any and all help is appreciated View attachment 243961 View attachment 243962 Screenshot_20230715_200447_Messages.jpg
    SM-N986U ?
  2. Fifen
    Fifen Member
    77
    33
    Utah
    Here is a diagram of the bolt I can't get out. Screenshot_20230715_201810_Drive.jpg
    SM-N986U ?
  3. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    I'll have to go out and look at my car now I have two of these here so you can't get the blow torch around on the other side of the frame member there I don't think there's a nut I think there's a threaded boss on the frame member that this bolt is going into so essentially now if you could spray some whatever you're poison penetrating mess in there and a lot of it to get it to run down that bolt and lean up against the threads that it's a millimeter or two out of let that soak like that now try to use your electric or pneumatic wrench to run the bolt in taking some of the juice you squirted with you 1 mm into the hole let it sit a minute and I'll try to back it out with the pneumatic wrench again spray some more run the thing in keep jogging it back and forth You may have success doing that You do it rapidly run it in push the button rap rap rap bring it back out spray some more button ready run it in repeat a little heat on the bolt if it starts to come out a little more you can add heat to the shaft it should run down to the threaded end heat travels pretty quick It helps No I don't think you'll make a fire even with the penetrating oil in there It will smoke.
  4. Fifen
    Fifen Member
    77
    33
    Utah
    I heated it up for a few minutes but couldn't get anything with the air gun or electric impact. I tried for a bit going back and forth and of course kept on hitting it with the penetration fluid but maybe I didn't do it long enough. Other videos I've seen they work at it for 5-10 minutes tightening and untightening the bolt while only stopping for the fluid. Maybe I can try again tomorrow.
    SM-N986U ?
  5. Tombukt2
    13,809
    2,504
    Durham NC
    Yeah they do it pretty quickly they're jogging that bolt back and forth If they can get heat on it at some point obviously you're changing the lower control arm so no matter of heating that up or overheating it or burning up the bushing or whatever the heck That's all going to be new I'm assuming. So at this point you just trying to jog the bolt out no matter what you do to the control arm metal or surrounding metal as that won't be there soon hopefully
  6. Fifen
    Fifen Member
    77
    33
    Utah
    I think if I got the bolt out completely I would be so happy I would cry. I don't care if the existing control arm and even the bolt are damaged. I can get a new bolt and I have a new control arm already. I just don't want it to shear.
    SM-N986U ?
  7. Tombukt2
    13,809
    2,504
    Durham NC
    Were the control arms damaged or the bushings so bad in the control arm you could wobble it side to side I usually just blast the ball joint off from the outer portion of the lower control arm and then take off the hub with the ball joint and the end link undone and then change the ball joint and the wheel bearing off the car right there next to it I haven't really seen control arms on my generations 3 bad yet like bushings unless they're bent in an accident which I haven't had yet so no need to take them off here anyway.
  8. Fifen
    Fifen Member
    77
    33
    Utah
    The bushings on the control arms were cracked but that's it. Knowing what I know now I wouldn't have attempted to remove them. But the ball joint, tie rod, and sway bars are all bad.
    SM-N986U ?
  9. Tombukt2
    13,809
    2,504
    Durham NC
    So you're replacing rackins on your steering rack too outer tie rod inner rack end. For dang near the cost of the four rack pieces you can get a rebuilt rack generally speaking for most cars I haven't priced it for a Prius but the rack isn't very special in the Prius very similar to all their other models It doesn't even have the large adjusting nut anymore for the rack to housing adjustment like they had previously but no matter. But of course if it's not leaking and everything is working well I guess doing the labor to put new boots and enter and outer ends maybe worth it to you.
  10. Fifen
    Fifen Member
    77
    33
    Utah
    Actually tie rods are the only thing I'm not replacing. Although I need to. The grease is leaking out. Tbh I forgot those were something I needed to take care of. But right now my main concern is getting the lower control arm bolt out. Cause the car is undrivable until I can get it out.
    I've never heard of buying a rebuilt rack. Honestly the oats I got weren't that expensive.
    SM-N986U ?
  11. James Analytic
    411
    63
    Michigan
    I wound up investing in a low mileage (~67K) steering rack, from a local salvage yard, that came with both inner and outer tie rod assemblies. Was like $10 more than the new outer tie rod I recall, ~$65.
    The gen 2 list the inner tie rod as a serviceable part, though for some reason the gen 3 does not. I had to change the inner tie rod on my 2013, so wound up just using the inner and outer tie rod from the drivers side.
    If I remember correctly, the inner tie rods are interchangeable on the gen 3's, though the outers are not.
    Wondering also, did you try the double ball peen hammer shock blows on the bolts and around the bolts and captive nut area? My guess is that's what helped free my front bolt out from the captive nut, along with the almost week daily penetrate plus some brake cleaner applied on two days as well as the impact back and forth action.
    Oddly, my rear not captive nut was seized along with the bolt, where both the head and bolt wound up braking off. Where the but side broke however was where I was able to cut using the oscillating tool.
  12. Mendel Leisk
    42,271
    Off-topic, but with your location I can believe it. Ever watch South Main Auto? In upstate New York, and pretty much every car he works on is a rust disaster.
    i idly wonder how much the road salt is costing, dollars, labor, down-time. There's gotta be more can be done, tighter regulation on salt quantities used, research into alternatives, taxk breaks for snow tires, whatever.
  13. Fifen
    Fifen Member
    77
    33
    Utah
    I live in Salt Lake City where salt is more abundant and cheaper than oxygen. It's no wonder my car rusts so bad.
    SM-N986U ?
    Tombukt2 and Mendel Leisk like this.
  14. James Analytic
    411
    63
    Michigan
    My guess, like the Phoebus cartel, there is collusion with the salt mines and related industries along with the big three to create such a situation. Probably the government is on board via lobbyists and/or actual elected officials interests that stretches into the road maintenance as well.
    My experience, up closer towards oh Canada there, when I was traveling back and forth earning my bachelors of science at Michigan Tech located in Michigan's scenic Upper Peninsula where in the Keweenaw Peninsula at least where there were plenty of mine stampings machines that left plenty of stamp sand for future generations, sand was the preferred material to use. Sand, that's it. Works great especially once freezes into the road.
    Reminds me of using gravel roads as a cost effective solution to road ways that don't require heavy loads routinely, albeit you'll need to plan drainage well and run graders occasionally to level the surface.
