Lower door rocker moldings
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Craigmri, Oct 12, 2010.
  1. Craigmri
    Craigmri New Member
    134
    Finally got the car clean enough to install the Moldings. Sorry about the poor quality photo but wanted to share this before my hellish week at work begins.
    Craig
  2. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    Nice. And a neat garage, too!
  3. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Looks awesome! How long did it take? How difficult was it? any tips to ensure prpoer alignment?
  4. Craigmri
    Craigmri New Member
    134
    Its fairly a straight forward install. I'm exceptionally nuerotic about alignment and fit so I was laying on the ground dry fitting the peices and then getting way forward of the car and looking at the site line to verify the line was straight from one molding to the next. Once I knew exactly how I wanted them only then would I pull the backing off.
    I also used a 1 foot straight edge to assure that the front and rear moldings were at same level.
    Its an easy install as long as you can lay on the ground and be patient. The adhesive is exceptionally sticky so be certain that you only press where you REALLY want it to go. I have no doubt they will stay on the car for 10 years or more. BTW, I used isoprophyl alcohol as a prep to clean the paint of contaminants.
    Craig
  5. Paul58
    1,126
    125
    Atlanta
    Thanks... Did you use tape to align them during your dry fitting? These are definately on my list of upgrades... Makes your prius look so... Lexus-ish...
  6. Craigmri
    Craigmri New Member
    134
    Paul, I did not use tape...I just used a close eye and a straight edge to assure the two peices were in proper alignment.
    Craig
  7. Paul58
    1,126
    125
    Atlanta
    Dang... You're gooood...
  8. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Really adds to the look of the car. I have always felt the 3 looked plain! But that smartens it up. H
  9. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    Looks great, and the care you took with the install is apparent.
    Now you've motivated me to put my set on -- they've been sitting here a little while while I did other things.
  10. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Did you ever get your set installed? If so how did it go?
  11. shrktank
    shrktank New Member
    56
    Imperial,Mo
    looks great!!
    I am awaiting for the dealership to get mine in so they can install them for me.
    I thought it would look great on my black prius
  12. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I used painters tape to hold & align the moldings in position as I don't know if I would have had a steady enough hand to do without it;). Came out as straight as can be. The trickiest part is once u peel off, make sure u have it in the right position because it's hard to take off & even if u could, I imagine it will compromise the adhesion to less effect. Here's my result:)
  13. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Can't wait to order mine and install them now thanks to you guys.
  14. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    Looks real sharp! Great job!!
  15. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    These look great, I like the look on the red where the trim color matches the rims.
  16. mr_logboy
    mr_logboy Junior Member
    22
    Portland or
    These were one of the first things I added and I love them on my Prius. It took me 30 minutes to properly clean lightly heat up and line up. I am very good with hands and eyes so did not use anything to line it up but it you did would not add much time. Think they add value to any Prius
