lower hatchback door
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dpham, Jun 17, 2013.
  1. dpham
    dpham Junior Member
    southern CA
    Dear, i own my Prius for 3 weeks now and still could not figure out how to adjust the Hatchback door to be lower when open... My wife have a very hard time to reach and close it...
    if anyone know, please help and thanks a lot in advance
    JMD likes this.
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Attach a bungee cord to limit how far it opens.
    52,862
    you can buy shorter struts, but the bungee is a simple and elegant solution.
  4. mactalla
    mactalla Junior Member
    I may help you to know (if you don't already) that there are two recesses in the door that give you a handle to use when closing the hatch without needing to reach all the way up to the outside edge. That reduces the height you need by a small amount.
  5. dpham
    dpham Junior Member
    southern CA
    thanks, can you help me please..
  6. mactalla
    I'm too new to post a photo, so let me try to explain it in words...
    Open the hatch of your Prius. When you want to close it, where is your wife trying to reach so that she can close it? Is she reaching to the painted metal part? Instead of reaching all the way up there, look at the black plastic just below it. On both the left and right sides there are holes just big enough to put your fingers. You can use that like a handle to pull the hatch back down.
    Let me know if that was unclear. Perhaps I should add a couple filler posts so I can post a photo or someone else here can do it for me. It still might be too high for her, but perhaps it's just right.
    dpham likes this.
  7. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  8. dpham
    dpham Junior Member
    southern CA
    Thanks you all for the input... so basically these struts CANNOT be adjusted... why should they (toyota) do that for little car. i also notes that it will hit my gargage door... :(
  9. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Mine also hit the garage door. However, a slightly expensive and fun way to fix it is...
    Install the TRD Springs. Lowers the whole car and the hatch doesn't hit the garage door anymore! Plus, it's more fun to drive!!!
  10. bisco
    52,862
    i glued foam the the door where the wing touches, but you have to park in the same spot each time. the gen III hatch is taller than the II.
    dpham likes this.
  11. Ariel1000
    Ariel1000 Junior Member
    I have the same Problem. The trunk door keep hitting the metal piping in the gargage. I was thinking using a towel and wrap the metal pipes. But the bungee idea is worth considering.
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Car performing as designed; Get taller wife.
  13. Ariel1000
    I went to Pepboys and bought the 19 inch tailgate lift, and now the trunk door does not hit the pipes in my gargage. And they install it for free.
