Lower left front control arm
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Alan Waite, May 7, 2026.
  1. Alan Waite
    Alan Waite New Member
    Newbury, Ohio
    I think I'm in serious trouble. While removing the lower control arm after breaking the ball joint loose and removing the rear vertical bolt, when I went to remove the front bolt it just keeps spinning. Is there a solution for this or am I going to have to junk the car? It is a 2012 Prius C vin B3.
  2. PriusCamper
    PriusCamper Senior Member
    13,345
    5,395
    Pacific Northwest, USA
    Your car will be fine... Once you comment or post 5 times you will be able to post links and photos and it'd be great to see a photo of the problem. Basically shops all around you deal with problems like these all the time. I've not done this job but either the bolt has failed or the threads the bolts go into have failed and once you get the bolt out you'll be able to figure out repairs.
