Lower Mileage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wayne, Aug 22, 2012.
  1. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Haven't been on the board awhile -- glad to see you guys are still going strong!
    I came tonight for some quick advice. I've been a 2005 Prius owner for 7 years now, been extremely happy, with zero defects so far (except a 12V battery at 5 years). However, my mileage this year has been down. Since I thought my Hybrid battery only had a 7 year warranty, I decided to have the dealer take a look at it. They are keeping it overnight to fix a leaky water pump they found (my first defect!), so I have some time to get some advice. They gave me a free Camry for the night.
    The issue is this: For 6 years over the particular route I drive I've averaged about 50 MPG in the summer, and 38 MPG in the coldest depths of our Indiana winters. That's fine -- my overall lifetime average has been 46 MPG. This year however, no tank has been much above 40. My last tank was 38. I've never had anything near 40 in the summer before. I don't feel I'm driving different enough to explain that big a difference. I drive a little faster, and have run the AC a bit more this year as we hit several new heat records, but that's about it. During the last tank outside temperatures were about normal.
    The dealer said the hybrid battery is fine, and everything beyond the leaky water pump is fine as far as they can tell. They say they can't find any problem that would account for that large a gas mileage drop. They say even my air filter is clean. So, since they will have the car through tomorrow, I decided I would log on here and see if anyone has seen this condition, and had something specific I can tell the dealer to check.
    My dealer also told me my hybrid batteries are now under warranty for 10 years/100,000 miles, so I still have 3 more years on them -- I know my paperwork says 7, did they change the 7 to 10 at some point? I live in Indiana, not California.
    Thanks for any advice you can offer. :)
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    There are so many, many reasons why MPG goes down... There's a worksheet you can use that usually makes it onto most of these types of threads... Just start searching and reading on here for an hour or two. I'm starting to think 'low MPG' is the most popular redundancy on PriusChat.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Change the Inverter Coolant and the trans fluid.
  4. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Heh -- I'm not a newbie to the board, or the car. I know all the normal reasons you can get lower gas mileage, and I'm not interested in any of them. I'm interested in malfunctions others have experienced that can account for the change.
    Right now I'm thinking about asking the dealer to check the current draw of the air conditioner.
  5. PriusCamper
    13,467
    5,435
    Yeah, I saw that, you commented on 682 posts...
    Regardless, newbie or veteran your overall MPG depends on so many different systems working perfectly that you can't just find one quick fix, you have to go by process of elimination. This problem is compounded by the likelihood that the dealer considers MPG betwee 38 and 50 to be within the normal range and not need of repair until the car throws an error code at which point the repair may be way more expensive. High MPG is more likely if you practice as much preventative maintenance as possible, which is what edthefox5 is suggesting with his input.
    Checking the Air Conditioner is also good idea... An AC pro on here said there is only 2 or three ounces of fluid difference that will make a Prius AC work full blast and waste gas vs. one that works efficiently... And most Toyota dealers are not seasoned experts when it comes to AC.
    Also 1/2 quart too much oil can give you bad mileage, so can bad alignment, or low tire pressure, or brand new tires, or inverter running hot cause of inverter pump dying, or your mass air flow sensor is dirty, or your throttle body is dirty because it's never been cleaned or is contaminated due to overfilling with engine oil, or one of your cells in your HV battery isn't up to par, or you need new spark plugs, or a new air filter, or you're lacking in basic maintenance intevals... It goes on and on, that's why someone is going to come to this thread and say please fill out the worksheet so you can eliminate all the possible causes of low MPG.
    A quick and easy one is to reboot your computer by disconcerting the 12volt battery for a little while, sometimes that helps to restart everything fresh and gets rid of any slightly off sensor readings or other electronic anomalies.
    As for the dealer: buyer beware on that... They are great at fixing stuff under warranty but once you're paying for it yourself, be careful. There are many stories of expensive repairs that dealers did that may have not been essential because the actual fix ends up being an different expensive repair. Kinda like your water pump leak. Some on here say that some of those leaks are better off just monitoring rather than making unnecessary repairs on. Many Prius owners I have met have passed on that particular repair and have driven their car for many years after without any further issue than just that little splatter that so many cars have.
    The more you can do this worksheet yourself the more affordable the repairs needed to get you back to high MPG will be.
  6. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Just to be clear, 38 to 50 is a normal range, but 38 all the time after experiencing 38-50 is way abnormal. My dealer agrees, my mileage is way low, he just hasn't been able to pinpoint a reason for it.
    Thanks for the suggestions, I will talk to him again in the morning. My car still has a bumper-to-bumper warranty for 30 more days, so the water pump is free. :)
    I will see if I can locate that spreadsheet. Unfortunately, most of those things only trim mileage, so I would need many to be broke to drop as low as I have. Still, I will see what it suggests.
    Thanks
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Hybrid battery warranty should be 8 years/100K miles for non-CARB states and 10 year/150K miles for CA and CARB states.
    Your warranty booklet should confirm the above and which warranty yours is eligible for. I believe IN is not a CARB state.
  8. PriusCamper
    13,467
    5,435
    Here... I dug this one up for you:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
  9. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
