Lowering a Prius?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Amymonel, Jan 16, 2018.
  1. Amymonel
    Amymonel New Member
    San Francisco
    2015 Prius Plug-in
    Has anyone tried lowering their Prius and whether if they've had success? How's the ride? How do you like the way your Prius looks lowered vs stock? Images are helpful too...
    I am curious about this since the Prius already has a very low nose (I scrape everything)
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Check out the coilover, air, and camber threads in this sub forum. Ride will depend on spring/damper settings. Driveabilty on making the necessary suspension geometry changes. Rarely done correctly in my opinion.
  3. Matth Torrijos
    Matth Torrijos Active Member
    121
    213
    Poway
    Lowering your Prius is quite easy, the only challenge is that you have to take off your wiper assembly on the front.
    Michael Craig likes this.
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Consider lowering springs, your ride quality will be better....
    Rob43
  5. Michael Craig
    Michael Craig Junior Member
    28
    46
    Oceanside, Ca
    2013 Prius Plug-in
    I’ve seen your Prius in Oceanside at the post office. Very clean.
  6. Michael Craig
    28
    46
    Oceanside, Ca
    2013 Prius Plug-in
    Did you end up lowering it? I lowered mine on kyb shocks and struts with H&R springs. Keeps the rake and lowers it nicely for a daily driver. Still a comfortable ride. I helped a friend with his and used Tanabe coil overs. Pretty much the same process, just had to spend a little extra time dialing it in.
    Either way, big improvement with handling and braking. Don’t forget to put in a TRD rear sway bar while you have it all apart. Really helps with the under steer.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    That all sounds great.
    Please provide a link to your 2017 Prius Prime parts, many here on PriusChat will be interested.
    1) H&R Lowering Springs
    2) Front and Rear KYB's
    3) TRD Rear Sway Bar
    Rob43
    #7 Rob43, Apr 5, 2020
  8. Michael Craig
    28
    46
    Oceanside, Ca
    2013 Prius Plug-in
    sorry for the confusion. I did this to my 2013 PiP. The 2017 Prime is stick still. My wife drives that one and won’t let me modify it.
  9. Matth Torrijos
    121
    213
    Poway
    Thank you I work by the area
  10. Michael Craig
    28
    46
    Oceanside, Ca
    2013 Prius Plug-in
    Nice. Keep it going. Looks nice.
    Matth Torrijos likes this.
  11. Matth Torrijos
    121
    213
    Poway
    Made the rear wider and got the new 4-inch flare to go with it
