Lowering spring,struts and rear sway bar for gen3
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Dragos, Oct 31, 2020.
  1. Dragos
    Dragos New Member
    uk
    Business Edition
    Hi.I have a 2013 gen3 Prius and I want to install H&R lowering springs and I have couple of questions?
    1.H&R go with factory struts or I have to replace them with shorter ones?
    2.Should I install a rear sway bar,does it make any difference?
    3.How low it will go with H&R as I have a C-WEST ELD body kit,do you have any pictures?
  2. jimontheocean
    jimontheocean Member
    53
    46
    SC
    Two weeks ago, I added the TRD rear anti-sway bar and it makes a big difference.
    Last week, I added the Cusco strut brace and my steering has improved. Well worth it.
    Purchased and enroute are the KYB struts and Tanabe lowering coil springs.
    I bought the oem struts off Rock Auto.
    No issues with the oem strut.
    I have heard with some rear lowering springs when you jack up the rear wheels, the springs can slip out of place, so must be careful when letting the jack down to make sure springs are positioned correctly. I am going with the oem rear KYB shocks.
    Thats my 2 cents...
    ModByCeasar likes this.
  3. jimontheocean
    53
    46
    SC
    One more thing, don't forget to do an alignment, you might get lucky and not have to shim the rear wheels, but from what I have read, I am preparing to shim the rear.
    TGrracie and Dragos like this.
  4. Dragos
    Dragos New Member
    uk
    Business Edition
    Hi.Thank you for your advice,in Uk is a bit hard to find the parts at a shop or dealership.I called the dealership today and they said that if the car wasn't suppose to have those parts they can't sell them to me.That's I'am afraid to replace the springs with OEM struts,I heard that the rear one's are shorter.
  5. jimontheocean
    53
    46
    SC
    I should have all my parts in the next few weeks, keep checking back and I will post pics and the parts I have used.
    I have done struts and springs on many vehicles, if you have the tools, its actually pretty simple.
  6. Dragos
    Dragos New Member
    uk
    Business Edition
    Thanks.I have tools and knowledge is not this problem,the problem is that in UK Prius is a taxi car not to many modified here.
    My question is if I can use the lowering springs with the OEM struts?
    If you changed the struts with shorter ones?
    What struts you used?
  7. h3x
    h3x Junior Member
    Poland
    Premium w/ Solar Cells
    You don't need to change the struts if you don't want to lower more than 30mm
    A few photos with H&R -30mm springs. With before & after ;)
    jimontheocean likes this.
  8. Dragos
    Dragos New Member
    uk
    Business Edition
    Thanks.No,I don't want to go lower then that. H&R 28972-1 what I have in mind.I have a C-WEST ELD body kit so mine will be lower then yours.
  9. jimontheocean
    53
    46
    SC
    Dragos likes this.
  10. dennis roudabush
    dennis roudabush New Member
    orange county , ca
    how is ride with springs on is bouncy looking to do same to mine just dont know what brand springs to get .
  11. redprius2011
    redprius2011 Junior Member
    45
    Georgia
  12. h3x
    h3x Junior Member
    Poland
    A bit stiff but they work fine. You don't need to roll anything.
  13. redprius2011
    45
    Georgia
    will it affect to the factory struts lifespan?
  14. redprius2011
    45
    Georgia
    sorry for bothering you but do you know which aftermarket shocks/struts will work with H&R springs? i know low springs will worn out the factory struts, because the aftermarket and factory spings has different compression/rebound ratio and the aftermarket one's is slightly shorter....
