Lowering the car today, need advice.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 5power, Mar 16, 2010.
  1. 5power
    5power Junior Member
    74
    cleveland
    I'm installing my df210 springs today. I just took all the plastic off to get to the front shock mounts... I got that done any advice for the rest to the job? any tips... I'm also installing spacers.. I should do a write-up... any advice would be grateful. Thanks Brandon
  2. 5power
    74
    cleveland
    Re: Lowing the car today need advice.
    Alright got the fronts done pretty easy, now for the rears and spacers... as for the spacers any info on how to press these in?
  3. Superdrol
    Superdrol Member
    399
    32
    How much did you lower it ? I lowered my '99 camry with coilovers awhile back. Half the bolts were seized and needed to be torched off. The newer car shouldn't be a problem though. Makes sure to post some pics I'd be interested to see it. I only had a breaker bar and did it by myself. Took nearly 10 hours total.
  4. Superdrol
    Superdrol Member
    399
    32
    Btw are u using the spacers because of wide rims ? Make sure you are using longer wheel bolts as well bc you will compromise the secure wheel fitment if they are not longer
  5. 5power
    74
    cleveland
    I finish the job in less than 3 1/2 hours by myself not to bad... the rear probably took like 20 mins one bolt and a fat guy...lol I wanted to take pics and do a write up but it was soooo cold out that I didn't have the motivation. But if anyone needs help just PM...
    I didn't do the spacers yet due to the cold weather.... that's tomorrows job. Thanks for the heads up on the spacers I got the ichiba and they come with extended bolts.
  6. hlkc
    hlkc New Member
    229
    US
    May I ask why you're installing the spacers? Are you putting the stock wheels back?
  7. 5power
    74
    cleveland
    I got a set of volk ce28 17x8 +44 and the front is flush but the back sits in a tad so with the 10mm I'll be at 17x8 +34 which I heard is flush so we will see. It's more of a look that I'm going for, not necessary...
  8. hlkc
    hlkc New Member
    229
    US
    The reason I asked is - it is a bit strange to install spacers in a new set of wheel.
    Please post pictures, it is beautiful set of wheels.
  9. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    pic please
    Robert
  10. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    You probably want to get used to swapping suspension because your stock shocks will most likely blow up with 20K miles on just lowering springs
  11. 5power
    74
    cleveland
    HAHA this is temporary buddy :rolleyes: coil-overs for the 2010 prius is not something I can get next day ship..... Try getting my sister who leaves in roppongi hills,Tokyo to get me a set but she's being a pain. In the mean time this will have to due until I head back. unless u can advise me a company that makes aftermarket shocks for 2010 prius?
    I find the pruis more expensive and parts even more hard to come by than my old E46 M3 unless u are sc24vr6:D Patient is key, gotta let the hybrid scene catch up here in the states.
    Pics are coming I just gotta get tires for the wheels.
  12. Superdrol
    Superdrol Member
    399
    32
    Coilovers are nice, but they are a pain in the nice person in terms of maintenance. I had the adjustable shock/spring compression. When the threads got dirty it was harder to adjust.
    I had my Camry's suspension so tight it felt like driving a go-kart. Fun, but I'll probably never do it again. I'd rather just go with springs.
  13. Superdrol
    Superdrol Member
    399
    32
    btw, be careful about how low you drop the car. I lowered my Camry over 5" and ended up killing the CV joints despite the car being perfectly aligned to be lower. The CV joints were not meant to twist at such a large angle.
  14. kiokenprius
    kiokenprius Junior Member
    84
    LA
    does your front sit about 1/2" higher than the rear?
  15. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    no pics yet?
  16. 5power
    74
    cleveland
    I'm sorry still need tires and lugs but here is a teaser of the wheels.... super light around 14 lbs 17x8 +44
    As for the drop there is a slight rake look with the back a little lower than the front... not to bad though.
  17. hlkc
    hlkc New Member
    229
    US
    Very nice. How much for just the silver version?
  18. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    Nice wheels! Be sure to post some pics after you are done.
  19. Superdrol
    Superdrol Member
    399
    32
    Are those Giovannis ?
  20. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    its VOLK Racing
