Lowest RPM's at highway speed?
Discussion in 'Gen 4 Prius Technical Discussion' started by tzx4, Mar 23, 2018.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am most familiar with the Gen 2, so I will use those numbers.
    If you go faster than 42, you have to spin the engine or M/G1 exceeds redline.
    You can't get the engine to redine lower than 62 MPH, or M/G1 exceeds redline. (in the other direction)
    Once you get to 105, M/G2 is at redline.
    Gen 3 added a reduction gear so M/G1 is not as stressed.
    RCO likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    PRIUS doesn't have a "CVT" like many new cars are coming supplied with (i.e. with a belt drive).
    PRIUS has an "eCVT", which has 3 power sources (2 electric motors, one internal combustion engine) driving through an epicyclic gearset, also referred to as a Power Split Device or hybrid transaxle.
    I'm not 100% certain that this simulator is perfect, but it gives an idea - figures for Gen 4 will be different:
    Toyota Prius - Power Split Device
    The WIKI article is very informative:
    Hybrid Synergy Drive - Wikipedia
    If you have a bit of time to spare (1½hrs), John Kelly has a full breakdown and explanation of the Gen 4 Hybrid transaxle:
    [If you want to see a "conventional" CVT operation, search for "weber cvt" in YouTube - he's got a few different videos showing how they work.]
    RCO likes this.
  3. fuzzy1
    10,690
    The Prius' electric CVT allows ratios all the way from zero to infinity, much wider than common mechanical CVTs. This is why you cannot meaningfully pin down Prius engine speed based upon wheel speed.
    Older Prius generations had RPM limits on certain components that required the ICE to spin at highway speeds for mechanical overspeed protection. Gen4 pushed those component limits higher, to where the ICE is no longer required to spin at all at (lower) highway speeds.
    pilotgrrl, RCO and alanclarkeau like this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Welcome to Prius Chat. You're just learning that your new Prius is far more complex and refined than you ever imagined. Enjoy your new car and the new learning curve it's presented you with. (y)
    fuzzy1 likes this.
  5. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    73 MPH is the fastest she'll go without ICE.
    RCO likes this.
  6. fuzzy1
    10,690
    Is that the non-Prime version? I've heard a higher speed as specific to the Prime.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's the speed above which the ICE must come on, no matter how favourable the conditions for just EV propulsion. Oh, and that's just the Gen 4 hatchback!
