LRR Tire Comparison...feedback from owners
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NineScorpions, Nov 16, 2011.
  1. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    ok guys, I have been reading and reading the forums trying to decide on a wheel and tire combo. I think I am hooked on the wheels...Drag DR-33 (machined face) which are 18x7.5, 22lbs, 45mm offset.
    The tires are still up in the air. Looking in the LRR category, it is slim pickings. The two tires I am looking at are (225/40/18)
    Continental ContiTouringContact CW95
    and the
    Michelin Pilot Alpin PA3
    I have read a lot about how the factory Yokas are weak in extreme weather. From the two above replacements, the Continental is a all-season while the Michelin is a winter tire. The Michelin is slight more expensive but also lighter. Where I am stumped is the reviews the two tires have received on tirerack's website. Continental is rated at 6.5 and Michelin is at 8.7. That seems to be a pretty substantial difference, but perhaps there is more two it? Any input? Is the Michelin really that much a better tire? I travel up north once a year into the land of the snow, so I am not opposed to the Michelin.
    I can already see that my upgrade will add approximately 9-11lbs per corner of additional weight (tire and wheel), so I have to let go of that one. That is why I am attempting to compensate by getting a LRR tire, even though they are more expensive. And even with all of that...I will need to lower the car.
    Cheers,
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Honestly the price of the Continental tire is so high that the fact it is LRR likely won't save you any money when compared to a lower priced non- LRR tire.
    I would suggest looking at the General Altimax HP. Only $115 vs. $209 for the Continental plus a higher treadwear rating and a 55,000 mile warranty vs. no warranty on the Continentals. The Altimax also rated well in Tirerack tests.
    I also suggest performing the calculations yourself based on your estimated annual mileage and expected lifetime of the tire.
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I have a set of them on other car and they grip in all conditions encountered so far but they don't roll as easy, MPG went down comparing to Avids they replaced.
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Agreed. Unfortunately the 18' LRR tire selection is very slim and VERY costly compared to something like the Altimax HP so even if you lose 3mpg you still come out ahead due to the large price difference. I usually do recommend LRR tires but this is an extreme case. :)
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Really when considering a tire in this class can you expect good FE? I don't think so. Large foot print can only mean poor FE! Hal
  6. NineScorpions
    375
    64
    Thanks for the feedback guys!
  7. NineScorpions
    375
    64
    wheels and tires ordered. I ended up going with the Continental DWS tires and the Drag DR-33 machined face rims. Should arrive sometime next week!
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    The DWS is a good tire.
  9. lpe350
    lpe350 Member
    56
    32
    Long Island
    I have DWS on 18x7.5 Advan T5's my mileage went down from 50.5 to 49.2 since my upgrade. Although my wheels are only about 17lbs each. I think you should be ok.
  10. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
  11. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    I like the Drag DR40's in gloss black with the machined lip, myself. 17's look nice.
  12. NineScorpions
    375
    64
  13. NineScorpions
    375
    64
    That is encouraging info!
  14. NineScorpions
    375
    64
    wheels and tires are in...Friday morning install. Let´s see how they turn out. :)
  15. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Post pictures or we'll ban you. ;)
  16. NineScorpions
    375
    64
    Here you are...
  17. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Looking good! :)
  18. Hal W
    Hal W New Member
    872
    53
    Look very goooooood! Hal
  19. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    Those look great. What offset are they? I was looking at the same wheel in a 17" diameter, which should weigh less but I was having a hard time finding the wheel weight. I was looking for a 17x7 wheel & a 205/50R17 LRR tire. Good to see the look though since I have a BP too. :)
  20. darelldd
    6,057
    388
    Northern CA
    Yup. That worked!
