LSPI and motor oil
Discussion in 'Other Cars' started by Trollbait, Jan 26, 2018.
  1. Trollbait
    11,560
    CleanMPG posted this, and I thought some might find interesting.
    Common Motor Oil Is About to Radically Change | CleanMPG
    With the increasing numbers of turbocharged and direct injected gasoline cars on the road, a new phenomenon has been discovered; low speed pre-ignition(LSPI).
    This can cause major damage to an engine, and the exact causes still aren't known. Oil formulation is thought to play a part, and oil companies are making changes to try an reduce the risk of LSPI.
