Lucus oil stop leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by amjohnson, Nov 13, 2020.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    Hello everyone I have a 2008 Toyota Prius with 300,000 miles on it I have a main rear seal leak and go through two and a half quarts of oil every oil change I'm wondering if I can add Lucas Oil Stop to my oil change to see if I can slow down the main seal leak?
  2. Landon51
    Landon51 Member
    190
    63
    US
  3. privilege
    privilege Active Member
    659
    169
    Birmingham
    I wouldn't use any "stop leak" products, in any fluid system.
    they tend to stop flow in places you don't want to stop flow like:
    cylinder passages
    heat exchangers
    small orifices
    pumps
    accumulators
    etc
    it's always better to fix the leak properly whether it's a seal or what have you
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Your thinking coolant stop leak he’s on the oil side.
  5. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    The effect can be the same, that stop leak stuff can easily block small passages.
    edthefox5 likes this.
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Oh yes it’s at best a temp fix at best with bad after effects.
