:mad: VSC got me in an accident today
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Maui, Aug 20, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Here is the technical explanation:
    During regenerative braking, braking force is generated by MG2 and applied to the front wheels through a normal differential (transaxle). Since the differential is not limited slip, loss of traction with either front tire results in a loss of all braking force. In this mode, the Prius has no means to control the braking force at individual wheels. When a loss of traction is detected by the traction control system, the Prius immediately stops regenerative braking and engages all four friction brakes. There is no delay testing for a return of traction: the transition is immediate and friction braking continues until the driver stops braking. The transition time is the sum of the time required to detect the loss of traction plus the time to pull in the friction brakes. It is a very short but finite amount of time, which feels longer relative to the nearness of adjacent traffic.
    Tom
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The memory in the data recorders is not infinite. The info from the collision was probably overwritten within 5 minutes of leaving the scene presuming you drove away. I'm sure we all drive distracted at one time or another so my only advice is "stop eating in the car".
  3. ibmindless
    ibmindless Member
    206
    I have experienced several episodes where the car seemed to accelerate when I was applying the brakes. In all cases, I was using light to moderate brake pressure. I drive rather slowly and don't usually have a need to use heavy or emergency braking. In the instances that I recall these episodes, slight pavement irregularities caused the sensation; not pronounced washboard surfaces or major potholes, just a slight rise or dip in the pavement.
    For example, a couple of days ago, I was slowing for a turn onto a perpendicular street. As I gently applied the brakes I could see a slight dip in the pavement - no more than 2", maybe lasting for 18"). I was traveling at 25 MPH. While steadily holding the brake pedal down, I felt a sudden surge of acceleration, lasting less than 1/2 second. This caused me to apply slightly more braking power - without an immediate response.
    I find this rather disconcerting. I imagine that is the same sort of reaction the OP experienced; however, in an emergency situation, it would be even more disconcerting.
  4. drees
    drees Senior Member
    1,782
    247
    Just FYI for those reading this thread:
    Often, a common side effect of ABS is actually longer stopping distances. The #1 goal of ABS is to keep the wheels from locking up so you remain in control of the vehicle and can steer. With the wheels locked up, you are only going to go into a straight line.
    Whether or not ABS actually improves stopping distances or makes them worse depends on on road/traction conditions.
    One common situation where braking distances will be increased with ABS is on gravel and snow.
  5. qbee42
    18,058
    3,079
    Northern Michigan
    That's all it takes. You don't need a major pothole to lose traction, especially with the crappy OEM tires that came with the Gen II. Hopefully the Gen III tires are better.
    Tom
  6. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    Lets not forget the "Law of Prius Braking Relativity" - The switch from electric to friction brakes is a momentary accelleration, the car is still slowing down with the friction brakes after the switch, but not nearly as quickly. The friction brakes are the same brakes all the other cars have, and slow the car down just like other cars too.
    Somebody needs to do a little You-Tube Einstein skit to explain this!
  7. bac
    bac Active Member
    863
    52
    Pennsylvania
    You (and you're far from alone) simple don't understand how ABS brakes work.
    The bottom line is that your braking distance would have be LONGER (and you would have lost your ability to steer!) sans the ABS brakes.
    Do some research, and try to understand just what the ABS braking system does.
    ... Brad
  8. bac
    bac Active Member
    863
    52
    Pennsylvania
    You couldn't be any more wrong with your last statement. Yes, in theory one could beat the ABS brakes, but not in practice.
    You are, however, very correct in terms of the ABS's real gem ..... steering while applying the brakes at 100%.
    ... Brad
  9. qbee42
    18,058
    3,079
    Northern Michigan
    Surfaces that allow material to plow up in front of the tires will stop faster without ABS. Harder surfaces more closely follow the ideal rules of static and dynamic friction, in which case ABS stops more quickly.
    Tom
  10. qbee42
    18,058
    3,079
    Northern Michigan
    A minor quibble: acceleration is greatest during braking. During the short transition between regenerative braking and friction braking the acceleration approaches zero. The problem here is that the term acceleration is commonly used only for forward acceleration, while from a physics standpoint it is any change in velocity, including accelerating around a corner while maintaining constant speed.
    Your statement is correct. I am just pointing out a small technical detail in terminology.
    Tom
  11. Maui
    Maui New Member
    Madison, WI
    I have new Goodyear Assurance tires, not the OEM integritys. Best tires in the world would do you no good when a computer chip removes breaking power for you.
  12. Maui
    Maui New Member
    Madison, WI
    Whether or not this is the way ABS brakes are supposed to work, I in some situations, this is certainly the way the Prius brakes do work in some situations.
    If intentional, I strongly disagree with this engineering philosophy. When things start going wrong, I think a computer chip should reasonably be able to do things like take away acceleration or apply brakes to one or more wheels. But when you get down to a tradeoff between stopping distance in steering, I have a hard time with the idea that it is reasonable for the chip to sacrifice my braking to ensure I can steer without problem. If the brake pedal is on the floor, I think without question the goal of whatever the chip does has to be to stop the car. Particularily in a situation that I have the brake to the floor and the steering wheel not turned, how does it make sense for the computer to second guess what action will best avoid a crash and instead focus entirely on giving me full steering control and no brake control?
    Like I said, I'm going to try to prove this weekend that my Prius has significantly worse stopping distance on a bumpy road than a normal car.
    BTW, I really don't think switching from re-gen brakes to physical brakes comes close to explaining what happened. First, if it took 2 seconds to make the switch, that is one serious design flaw. Second, the indicator light on the dash was flickering the whole time. Third, I've had numerous cases where I've had this loss of braking when only braking after hitting a bump where I was not at all braking hard (and a switch to physical brakes shouldn't have been necessary.
  13. Tideland Prius
    16,559
    non-ABS cars will stop faster on loose gravel or loose snow as qbee42 explains.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Yes yes yes... i know exactly what you mean. There's a bump right before a store I go into all the time and traffic is really fast there so you have to kinda roll in to the store parking lot fast or you'll get r-ended. First time or two I hit that bump while rolling in and as you say all braking goes away for a second. Man its terrifying if you don't know about it the first time it happens at speed and you expect a fast pull down and instead....you got nothing!!!!
    I'm not voicing any opinion on exactly what your situation was as all the posters here have excellent points but I do know what you mean.
  15. Flying White Dutchman
    4,376
    313
    on loose gravel?
    sofar i understand is
    the wheels then block and you glide over the loose gravel.
    with abs the car will prevent blocking and give you still some grip for turning the wheel to prevent hitting something.
    abs is not for stopping a car faster its for keeping some controll over the car and be able to still turn the car away form a collision
  16. qbee42
    18,058
    3,079
    Northern Michigan
    Agreed. The transition to friction braking is very fast. It feels scary, but it doesn't take anywhere near two seconds. In your situation the problem was almost certainly the road surface combined with tires and suspension, which combined to produce a lack of braking. It happens. I've had it happen in my old Jeep, which has the most primitive and un-computerized brakes that you can imagine. Once tires start bouncing and sliding, you don't get much friction.
    Of course we can't completely discount the possibility of a bug or design error in the new Prius braking system, but it is unlikely given the safety and fail-safe nature of this system. Generally the simple answer is the correct answer, which in this case is the road surface. If it is a design error, only additional incidents will prove it.
    Tom
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Absolutely you will stop faster on a gravel road, if you can lock up the brakes. At 50 km/h on the gravel road to the hobby farm, I could stop up to 2 car lengths sooner
    The vehicle can "dig in" a bit to stop faster. With ABS, the loose stones on top act like ball bearings, and the ABS pulsing dramatically extends the stopping distance
    In normal real world driving conditions, I much prefer having modern equipment like ABS and VSC
  18. Flying White Dutchman
    4,376
    313
    ok
    but is abs not made just to have some steering controll when braking and not for stopping distance.
    in a car without abs and locking of the wheels during hard braking will give you no control over steering direction with abs it will and thats what its for.
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Yes, the primary purpose of ABS is to allow you to remain in control while braking, not necessarily to shorten stopping distances
    Without ABS, as highway speeds if you have to suddenly stop, most likely the car will go sideways, possibly spin out
  20. Tideland Prius
    16,559
    Yup. but if there's loose snow or gravel, locking up the wheels will probably stop you before you hit an object (the deeper the better of course). On hard packed snow, you'd want ABS to help you steer around the object.
