Magnetic Drain Plug
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by radiocycle, Aug 23, 2009.
  1. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I tend to agree... if the existing plug can simply be modified with a super strong magnet, the oil at the bottom is less turbulent and should be the best place to collect particulates.
    Small magnets are cheap.
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I just ordered the magnetic drain plug.
    I will also try to attach a hard drive magnet which are neodymium (super strong) to the outside of the oil filter.
    Can't hurt it's on the outside.
    I'll report back at my first 1000 miles oil change.
    my2cents.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Sump plug magnets are a good idea, but providing the oil filter is doing it's job the only thing they protect is the oil pump as this is between the oil sump and the filter thus pumping unfiltered oil. Damage to the pump can usually be seen in a dismantled pump as scoring, this damage will lower oil pressure and flow. Strong magnets do there best job if placed on the outside of the sump immediately below the oil pick up tube and once fitted should not be removed.
  4. kehyler
    kehyler Member
    84
    32
    blah
    Why should they not be removed?
  5. kenmorem
    kenmorem Junior Member
    Puget Sound
    so what were the findings with your new magnet?
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    get a used non ssd computer hard drive and unopen it up. the magnets inside are one of the strongest magnets ever. stick one against and pole and good luck, triple dog dare.
