Magnetic Oil Drain Plug
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Apr 9, 2022.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Figured why not and got one of these to slap on the next oil change I do.
    Anyone else have input if you use one and how it works for you feel free to chime in. 20220409_175738.jpeg
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    The aluminum plug is made of a softer material with less tensile strength than the steel oil pan threads. Therefore, it will sacrifice itself before deforming and damaging the steel threads.
    The magnet is helpful in detecting and capturing damaging iron particles which basically only exist in the piston rings, cylinder liners and the oil pump.
    Jim Swart likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    How dare you not give us a link to buy one! Where did you get this?
    When I first got my '07 in 2012 I researched magnetic oil drain plugs for Prius to death and couldn't find one. Are Gen3 & Gen 2 plugs the same? Sure hope so!
  4. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    They are all the same M12x1.25 thread pitch for all Toyotas.
    Magnetic Oil Drain Plug m12 x 1.25, 2 pcs of Pack Magnetic Sump Drain Nut Oil Drain Bolt (With All Vehicles with 12x1.25 Threaded) Red & black
    Jim Swart and PriusCamper like this.
  5. AzusaPrius
    2,258
    952
    Where are my manners, Im sorry the link below will take you to the one I bought.
    <a target="_blank" href="
    ">Magnetic Oil Drain Plug</a>
  6. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Having worked in the aerospace industry for more than 30 years, in the case of the drain plug, I would prefer 6061 to 7075 alloy for the drain plug, since 7075 has the equivalent tensile strength of mild steel used in the oil pan's threads.
    I want the plug to give before the threads in the oil pan. In this case, weaker is better. 6061 exceeds the need. Yet it is weaker than steel and will be ductile deform from stretch instead of frangible fracture.
  7. Mendel Leisk
    42,372
    How effective is a magnetic drain plug on the engine oil pan; does it collect much?
