Magnetic Transmission Drain Plug
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Aug 26, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    They no longer put these on the 2010-2015 Prius models so I got one to put on when I change out my ATF
    Should help collect any loose metal shavings floating around. 20240826_172407.jpeg 20240826_172336.jpeg 20240826_172303.jpeg
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I prefer the widely available M18x1.5 aluminum magnetic oil drain plug with a 19mm hex head.
    That way I will again have to deal with the 10mm Allen hex socket bit.
    They are cheap enough that I use them for the transaxle fill and drain plugs as well as the inverter coolant drain plug.
  3. AzusaPrius
    2,258
    952
    Never saw you post anything about it, got any pictures of it?
    One for the inverter coolant, that is strange to use it on.
  4. Mendel Leisk
    42,372
    What’s the thread dia/pitch?
    ^ Answered above by @Georgina Rudkus.
    And the hex pocket, 10 mm (per stock)?
  5. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Just search Amazon for M18x1.5 magnetic oil drain plug and find the ones with a hex head.
    If you prefer, they can also be had in stainless steel.
    I like aluminum, because it is less likely to corrode when in contact with the cast aluminum transaxle case as well as the one on the inverter drain.
    It is also less likely to corrode when in contact with the aluminum crush washers.
    The steel plugs are a carryover from the days of steel transmission pans and cast iron diferential cases.
    Toyota did not evidently want another part number to carry on inventories or the associated extra costs.
  6. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    I prefer the ones with the 19mm hex head that will never strip out. I just use a 19mm socket, which I already have.
  7. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Contrary to the official Toyota service manual and conventional wisdom, the full engine undercover need not be removed to perform the transaxle fluid change.
    Here is the view with the oil change door opened.
    Both the drain and fill plugs can be accessed through the opening of the oil change door which allows both plugs to be removed and reinstalled with the proper length socket extensions.
    I also cut a hole in the engine undercover carefuĺy with a hole saw directly under the inverter coolant drain plug. This allowed removing and reinstalling the inverter drain plug without removing the engine cover at all.
    Here's what I did before I switched to the aluminum hex head drain plugs.
    #7 Georgina Rudkus, Aug 26, 2024
    MAX2 likes this.
  8. Mendel Leisk
    42,372
    Moot point for me; I take the full panel off for every oil change.
