Main Battery light flashed briefly while braking when exiting highway in neutral.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by maleko, Feb 1, 2017.
  1. maleko
    maleko Member
    102
    36
    Central FL
    My 2008 Prius (~130k mi) MAIN BATT light flashed briefly last night (barely half a second- long enough for me to hear a few strange beeps and see the red main battery triangle flash and go right back off) just as I was getting off the highway with the car in neutral and performing a firm hard stop from high speed to try to bed the new rear brake shoes/drums that were just replaced.
    The rear wheel cylinders were also replaced and the brakes feel a bit "off" now whereas before they were very firm and almost a bit too grabby, especially at slow speed stops- I found this to be a symptom of abnormally wet weather (which we have been having this winter in the Bay Area of California) based on my research so far.
    I found that strange considering I drive it between 80mph and 100mph like a race car regularly and figured the brakes get worked out pretty aggressively in a day to day basis when I'm at the wheel- but I guess overnight is enough time for a thin layer of oxidation to work it's magic and make my slow speed stops harsh and abrupt?
    I haven't driven it enough yet to decide if it's just the rear shoes that haven't fully seated/burned off their residues yet or if I may have a small pocket of air trapped that needs to be bled out. I did a small one-man bleed on each side just enough to fill the wheel cylinders, barely any loss of total fluid amount and no abnormal codes or warnings have been set since replacing my rear brakes two days ago- I was very careful with my procedure.
    Any idea the relation here?
    I checked my 12v battery and it was at 12.23V as of this morning and dropped to around 11.5V when loaded with headlights and brake lights with the accessories added. I know a bad 12v can throw all sorts of weird stuff around but I thought my 12v was good until it starts dipping into the 10V range?
    I will update as I get more driving in. I usually drive it 90 miles round trip every morning taking my wife to work in SF.
    Thanks!
    -Mark
  2. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    Any codes?
    Did you see the text "MAIN BATT" on the display? Or was it just red triangle and beeps?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    US is gauge, but I would be finding a new 12 volt battery.
  4. maleko
    maleko Member
    102
    36
    Central FL
    Yes I saw the words "MAIN BATT" inside a small red triangle in top left corner of the center (MFD?) display screen.
    Also, I just noticed that now when I put my foot on the brake with car in drive (like I'm waiting at a stop light) that the battery is sending power to the electric motor and from there to the front wheels. No matter how hard I press on the brake pedal it wont stop the power flow. Before I changed the brakes it would do something similar where it would continue sending power (according to MFD) to the front wheels until I stepped on my brake pedal a little bit harder and that would always stop the power flow.
    My check engine light has been on for months because I kept getting random EVAP SYSTEM codes suggesting that my fuel tank's check valve was stuck.
    Let it be noted also that last night when the main battery signal flashed I had only 1 bar on my traction battery in the MFD at that moment. I regularly see the HV traction battery dip to the bottom 1 or 2 bars fwiw.
    Also to note we have the dead dashboard problem so more often than not I have zero to minimal lights on my dash (besides check engine or maintenance required lights).
    I picked up a Tech Stream scan tool to be used with my laptop but I have not finished setting it all up. If anyone has some helpful tips or pointers regarding that I am open to suggestions.
    I will post the picture I'm talking about of the power going to the front wheels while stopped fully at a light in drive.
  5. Mendel Leisk
    42,355
    This is off-topic now, with your hybrid battery issues, but I'm not sure it's a good idea to break hard on new pads/shoes. From the Owner's Manual, this is new vehicle break-in period, but I believe the last line is applicable after any pad/shoe replacement as well:
  6. bisco
    52,863
    welcome!
    agree with jimbo, check/charge/replace the 12v. how old is it?
    could be your hv battery has a weak cell, are you in a 10/150 state?
    maleko likes this.
  7. Augustus88
    87
    29
    Birmingham, AL
    Three Touring
    If your charge level is regularly dropping to 1-2 bars during normal driving, you almost assuredly have a failing battery.
    Also, when you are in neutral, there is no way for the car to charge the battery - If the car felt the need to charge the battery and you were in neutral, it will trigger a red triangle until the car is put into park or drive. Since you were in neutral, and had one bar on the MFD, the car most likely wanted to charge the battery. I feel like this may be your issue.
    Also, as for the battery sending power to the motor when you are stopped in drive, even with your foot hard on the brake... That is strange. Mine always stops flow if I press the brake a little harder. I usually put the car in neutral at stop lights so that I don't have to clamp on the brakes harder than necessary.
    The best way to bed in new pads/rotors is to warm them up with moderate braking a few times, then once they are warm, hit them hard a few times until pad material transfers onto the rotor face. Failure to do this may result in brake judder, also known as 'warped rotors', where an uneven pad transfer material forms on the rotor face. Most normal people can't handle this, so the next best way to break in brakes is to just be very gentle and let interstate off-ramp trips do the pad transfer work.
    #7 Augustus88, Feb 1, 2017
    maleko likes this.
  8. Mendel Leisk
    42,355
    TireRack agrees with you. Still, putting in new pads since the '80's, all I've ever done is put them on, never did anything to the rotors, took it easy for the first little while, and never noticed any judder, pulsation. I have had dealerships do it a few times as well, and sometimes they would remachine the rotors on the car, don't think it does much more than reduce the rotor's lifespan.
  9. Augustus88
    87
    29
    Birmingham, AL
    Three Touring
    Usually you are fine if you just put them on and drive normally. Its not the best way to do it, but it usually ends up just fine.
  10. maleko
    maleko Member
    102
    36
    Central FL
    Mendel I hear what you are saying but I'm not really a guy who goes by the owners manual. That information is generic at best and not always best practice, but easiest/simplest practice for most people who aren't very technical. This is all my opinion of course, to each their own.
    Bisco, I am in California which is a 10/150 state afaik. I would not doubt having a bad cell or few with the way I drive- I know it's just part of the deal. Also we purchased this car used with about 70,000 mi. I have changed the spark plugs, several air filters, oil and filters of course, changed the transmission fluid, front brake pads and rotors, rear wheel cylinders, drums, and shoes, cleaned MAF, throttle body, intake, PCV valve, cleaned the battery cooling fan, etc. I am new here but certainly not new to mechanics or troubleshooting. I drive my vehicles hard- to their limits- but I am religious about high quality maintenance.
    I am curious if I can still get the traction battery replaced if 1.) I am not the original owner, 2.) my dash combo meter is blacked out (and not counting miles afaik) 90% of the time- today was a rare exception it came on! And 3.) how bad does the traction battery have to be to get official Toyota-sponsored replacement?
    Augustus88, I completely agree with your theory- it makes sense since I normally don't use neutral gear often, but I definitely use B for engine braking daily typically. It turns out, despite my being careful as possible when doing the brakes Monday, that it did in fact set the ABS and ! inside a circle symbols on my dash! I didn't know this until my dash decided to randomly work this morning, thankfully. I promptly performed the 4/13 pin paperclip reset special on the OBDII port and reset the braking system before driving my 40ish miles home. Immediately I could tell the braking felt different (the rear brakes were finally grabbing properly along with the fronts) as the rear didnt lift and then settle when coming to a complete stop. 40+ miles later, no brake system warning lights have come on, brakes feel 100% on point now, and best of all that weird 'not stopping power to the front wheels' stopped when I cleared the brake system warnings.
    Finally, yes I understand the brake bedding procedures and properly burned in my front rotors and pads when I replaced them months ago per the manufacturer's recommendations (not the owner's manual guidelines). I can 100% say proper burn in is essential in performance type pads. The front pads I put on from RockAuto are these:
    POWER STOP Z23822
    And I can honestly say they are some of the nicest front brake combos I have used- highly recommended.
  11. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    Correct CA is 10/150.
    1. Doesn't matter, the warranty is transferable;
    2. Probably works in your favour, but in any case there is an extended warranty to fix a dead CM (combination meter), so I'd get that fixed ASAP under warranty;
    3. You only need to get DTC's that indicate a bad battery — P0A80 and/or P301x and sometimes P3000 pops up, but I think on its own the P3000 doesn't necessarily indicate bad battery as it is a general fault code–it could mean many things. If you are inside both the 10/150, it is a no contest warranty repair.
    If you get your MVCI setup you can check for these, but don't clear them as the dealer needs to see them. Having said that, if your battery is bad, they will come back pretty quickly.
    #11 dolj, Feb 1, 2017
    maleko likes this.
  12. bisco
    52,863
    agreed^^^ you need the P0A80 to get warranty. otherwise, the battery is still considered operational. but you still have a year, and driving it the way you do should exacerbate the issue.
    maleko likes this.
  13. maleko
    maleko Member
    102
    36
    Central FL
    Last time I brought our Prius to our local stealership regarding our dead dash they basically told me I will need to leave it with them to diagnose and IF they determine it is the combo meter fault it should get replaced in a few days time, etc on Toyota's dime. BUT if it's "not" I'm on the hook for their BS $100+ diagnostic fees and then some depending what BS they think they can try to fool me with. I tried explaining to them I have thoroughly read up on the issue (that they try to pass as not an issue at all) and knew it was a faulty combo meter dash display unit, but they insisted other things cause similar behavior. If I recall correctly in my brief exchange with them that morning they suggested it was likely my 12V battery (which at the time it was NOT, but I know it's end is near now and we don't even have the extra money for me to replace it myself), let alone get screwed for several hundred from Toyota. Bottom line is I don't trust them, their service people, or mechanics to not get screwed financially. If anyone knows of a 'reputable' Toyota dealer in the Bay Area that is cool about making this repair I will gladly bring it there.
  14. maleko
    maleko Member
    102
    36
    Central FL
    Honestly, that's kind of been my goal to an extent. ;) lol
  15. bisco
    52,863
    at this point, it's probably a good idea. we've had a few members get a brand new battery at the very last second.
    but even if it takes a little longer, toyota is usually pretty liberal with goodwill.
    maleko likes this.
  16. maleko
    maleko Member
    102
    36
    Central FL
    I will say it definitely has less pulling power when the HV battery is low- like it struggles in the 90's to catch 100, but when my bars are in the blue range it seems to pull to 100+ considerably easier.
  17. bisco
    52,863
    yep, not too many horses under the hood.
  18. maleko
    maleko Member
    102
    36
    Central FL
    Surprisingly I manage to average about 32 mpg with aggressive commuting. When I drive it "all out" it dips below 30's sometimes.
    m.wynn and bisco like this.
  19. dolj
    dolj Senior Member
    8,652
    4,402
    You are right not to trust them. Get them to pull up the CM TSB and get them to read it. The only thing they need is the customer's report that it goes dark, they do not need to see it for themselves. It does take several days, as they need to get the failed combo out and then send it off. A new combo is programmed with your milage and set back to them be fitted. Get them to read further, where it says they need to give you a free courtesy car to use while yours is in the shop.
    The TSB is attached to this thread: T-SB-0172-09 Combination Meter - Intermittent Display, which you can print off and highlight the relevant bits, and present to the service writer if they put up resistance.
    It could be other things, but if your battery does not drop under 11 V on initial boot up it is not likely. I have seen it reported that a low battery can cause the CM to go dark, but not sure why, unless the low voltage interferes with the voltage regulator chip starting correctly.
    Anyway, the short story is they shouldn't give you grief.
    Hope that helps.
    PS, I don't know what your electronics skill level is, or whether you have the inclination, but there is a thread here that has the information you need to fix it yourself.
    m.wynn and maleko like this.
  20. maleko
    maleko Member
    102
    36
    Central FL
    Great info here, thanks a ton! I will attempt the Toyota dealer battle first to see if we can get it done on the books, but it's funny you ask about my electronics level of skill because I used to be an appliance repair tech full time. I am also going to school for Mechatronic Engineering so that's absolutely right up my alley of interest and skill.
    When I looked into this in the past, logistics issues and finances were our primary discouragement since we are pretty reliant on this car since moving to the edge of the bay and having a baby.
    Do you know if they base this off of the vehicle year or does it go by months? I'm pretty sure our 2008 is right down to the line in terms of the time frames specified for replacements allowed.
