Maint Req Light Lit but no codes
Discussion in 'Gen 2 Prius Main Forum' started by romad, Apr 11, 2022.
  1. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Subject says it all. However, I noticed that the odometer was reading where, after a previous oil change, the next service would have been due. I had the service done earlier than the projected date so it isn't due for another 4,000+ miles. Is it possible that they didn't reset the interval? Is there a way that I can reset the interval?
    #1 romad, Apr 11, 2022
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    This question drives me crazy... I get people texting in a panic claiming dash warning lights are on no matter how many times I explain to them what this light really means. To turn the light off, set your odometer screen to total vehicle miles, not trip miles and the turn the car off. Then when turning the car back on hold down the odometer button and watch the odometer screen count down till the light turns out.
    romad likes this.
  3. romad
    320
    57
    Prescott, AZ
    Thanks, that did it! I then waited a few minutes and started the car again to check & the light went out with the rest as it was supposed to do so.
  4. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Just be aware that the light will trigger again in 5,000 miles (starts flashing at 4,500) but you will need to do your next service in 4,000 miles, so the light will not flash until you're 500 miles overdue. You'll need to do the service on miles on the odometer and do the reset again to get back on track.
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Maintenance required light is just what it looks like; a reminder that it's time for your next scheduled maintenance. There is no trouble, so no trouble codes.
    In the owners manual:
    A few pages later is the description and the silly, non-intuitive chicken dance to reset it. This is the 2007 manual. I'm sure the 2004 says the same thing.
    srellim234 likes this.
  6. romad
    320
    57
    Prescott, AZ
    Yes, I know. Because I could NEVER get the oil change done on even 5K increments, the last due mileage was 161,xxx but I was able to get the car in at 160,319 miles so my next scheduled service is at 165,319 miles. However, when the light triggered yesterday at 161,6xx miles I figured it wasn't the oil because, since the service had been done at the dealer, the interval had been reset. That is why I checked for any codes. I'll also make certain to tell them to reset the interval at the next service. Though, maybe, I should ALSO do it when I pick up the car, just to be safe! :D
  7. romad
    320
    57
    Prescott, AZ
    That is different than on my 2005 VW Jetta TDI where the Maint Reqd indicator covers all faults so you have to pull the code(s).
    And my 1990 Mazda Miata doesn't have OBD II.
  8. PriusCamper
    13,452
    5,430
    Or you can just put a smiley face sticker over the light and be happy forever as long as you remember to change your oil on time. :)
    srellim234 and Mendel Leisk like this.
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    Faults on a Prius will give either a check engine light, a master warning light (red triangle), a brake trouble light, a check hybrid system warning, or some combination of those or others. Maintenance required just means it's time for maintenance. Maintenance isn't the same as repair.
  10. dolj
    dolj Senior Member
    8,640
    4,391
    That being the case, I'd forget about the hundreds of miles and make your next booking for 165,000 +/- 100 miles, then it is easy to remember. It is not like if your engine is a mile or ten overdue it's going to blow up. With it now being due on the even 5,000-mile mark, you are not dependent on the light (which we don't even have in NZ/AU/UK/JP, btw) if someone at the dealer forgets to reset.
    Interestingly, it just occurs to me, that if the light reset was overlooked, it would have still been illuminated when you left the dealer. So with it off (I'm assuming, you would have noticed if it was on), then it comes on at 161,xxx means something else is at play here.
  11. PriusCamper
    13,452
    5,430
    Can I text you phone numbers of people who need to hear this so you can call them and I don't have to get upset anymore because someone wrongly claims their car I fixed have warning lights again? Lol!!!
    No matter how many times I explain what you explain they do it again...
  12. Mendel Leisk
    42,338
    Yeah, Toyota Canada did that for us: no maintenance light up here. Somehow we muddle through.
    jerrymildred and PriusCamper like this.
