"Maint Reqd" warning light question
Discussion in 'Gen 2 Prius Main Forum' started by BoosPrius, Jun 7, 2006.
  1. BoosPrius
    BoosPrius New Member
    109
    Louisiana
    the manual says this warning light means the oil needs to be replaced. Does that simply mean that the computer has kept track of the number of miles since the last oil change, and a new one is now due, or does it mean there is something wrong with the oil, such as contaminants, etc.? Thanx.
    Gary
  2. catsbox
    catsbox Member
    295
    Bellevue, WA
    <div class='quotetop'>QUOTE(BayouBulldog @ Jun 7 2006, 10:08 PM) [snapback]267646[/snapback]</div>
    I saw mine for the first time today and pulled out the owners manual to see what it meant. I had the same question. I suspect it is just a reminder that it is time for the oil change, as it has been just under 5000 miles since my last one. I sure hope its nothing more. Sorry I could not answer your question.
  3. CinciPrius
    CinciPrius Member
    110
    Cincinnati
    <div class='quotetop'>QUOTE(catsbox @ Jun 7 2006, 10:22 PM) [snapback]267657[/snapback]</div>
    It's based on your mileage.
  4. brandon
    brandon Member
    771
    Manhattan, KS
    See this post.
    The Maint Reqd light is simply a reminder light that is supposed to be manually reset every time the oil is changed. The owner's manual details the exact function of the light and how to reset it.
  5. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Additional info: the check engine icon is the one that indicates a problem, vs. the "Maint Req" reminder light.
  6. brandon
    brandon Member
    771
    Manhattan, KS
    Good point. Many have confused the two in the past.
