Maintaining gas tank at 3/4
Discussion in 'Gen 3 Prius Fuel Economy' started by Stephan Jefferson, Sep 25, 2019.
  1. Stephan Jefferson
    Stephan Jefferson New Member
    Long Beach, CA
    A fellow Prius owner told me that he keeps his fuel tank at 3/4 full to be lighter and therefore gets maximum fuel economy. Thoughts?
  2. frodoz737
    frodoz737 Top Wrench
    4,790
    2,554
    33
    Due respects, but this "fellow Prius owner" suffers from MPG OCD.
    #2 frodoz737, Sep 25, 2019
  3. Leadfoot J. McCoalroller
    8,260
    7,763
    Pennsylvania
    2018 Prius c
    The fuel saved by not carrying another 12lbs of fuel…
    I mean it’s not nothing, but yeah….very OCD disorder.
  4. CR94
    CR94 Senior Member
    2,813
    1,235
    Northwestern S.C.
    Filling it full and running it down as low as you safely can will use less fuel overall, due to fewer trips to refill.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    One gallon of water weighs 8.34lbs. A turd gen gas tank holds 11.9 gallons so 1/4 tank less is saving your friend 25lbs of weight.
    An extra 100lbs of weight in a typical vehicle will reduce fuel efficiency by 2%.
    I will let you draw your own conclusion with those facts.
    #5 Grit, Sep 25, 2019
  6. Mendel Leisk
    42,228
    Something lost in translation? Maybe he fills to 3/4 full, roughly, then lets it drop, refills when it's getting low?
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Without wipers, I get an extra 1mpg to the tank. 10 more miles that I can drive (y)
    Stephan Jefferson likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I was thinking the friend refuels before or after each drive to keep it at 3/4 tank compulsively, I mean constantly.
  9. frodoz737
    4,790
    2,554
    33
    fuel is 6 lbs per gal. so about 18 lbs. less at 3/4 tank. Don't take out the back seat, spare, rear wiper, be afraid to run the butt warmer or a/c either. It's a hybrid that already gets better mpg than just about anything else out there regardless. ;)
    jerrymildred likes this.
  10. Mendel Leisk
    42,228
    I'm constantly toting a jump pack that's nearly 20 pounds. :oops:
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    20 pounds :eek:.
    The LiON jump pack I have maybe weighs 3 pounds;).
    Christmas is just around the corner for an upgrade and hand-me-down of your current one:).
    Think you’ll even get an mpg benefit from the potential gift, so a win-win(y).
  12. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    All the above, or you could lose 18 pounds of body weight to save fuel.
  13. bisco
    52,746
    that's what i did, win/win
    of course, i only put 3 gallons in at a time
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Depends on the "typical" use.
    Extra energy will be needed to GET that extra mass moving......but almost no extra will be needed to KEEP it moving.
    Even with a lot of stop and go, your 2% seems a bit high. Where did that figure come from ?
  15. Leadfoot J. McCoalroller
    8,260
    7,763
    Pennsylvania
    2018 Prius c
    Let’s not forget the energy spent typing ’s p a r e t i r e’ 8x a day :D
    jerrymildred and Mendel Leisk like this.
  16. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    One thing I will say...is that when I remove the rear seats on the Prius v (wagon), the MPGs do noticeably go up. So yeah....obviously a weight decrease will improve MPGs ( it's physics! ). (y)
    However, like others have said, you have to have extreme MPG OCD to think a couple gallons of fuel will improve MPGs much. However, *technically*, it will improve a bit.
  17. Mendel Leisk
    42,228
    Our 17" rims weigh in at 24 lbs apiece IIRC. Unsprung weight? That'll get the engineers out of the woodwork.
    Well actuality, think it's 18 pounds. Still, I like it, suspect it has more "legs" than the new fangled ones. I've never used it for our Prius, it's for all and sundry, so maybe heavy/old-school is better? It's the Clore JNC660.
    #17 Mendel Leisk, Sep 26, 2019
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No wonder gas prices are still going up, some folks are not doing their part :LOL:
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thin air...that’s been polluted by humans.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Eureka !!
    That's the solution: Stop breathing.
    (Mostly joking.....but SOME days..........)
