Maintaining Speed on grade and CVT
Discussion in 'Gen 3 Prius Main Forum' started by Mobalized, Sep 16, 2013.
  1. Mobalized
    Mobalized Member
    98
    27
    So I knew the prius was doggy before buying, and it has more get up and go on hills then my 94 Honda Del Slow. But... It struggles to maintain speed over small inclines in the road without constant pedal adjustment. Obviously climbing a hill I expect to ease into the gas more. But even at 50 mph over a short rise the cars speed falls quickly and requires the pedal to be depressed more and more. This is the only car I've owned that has required this much adjustment. Is this because of the cvt?
  2. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    welcome to the world of the prius. So many owners learn the value of the cruise control on the prius. Try to use it as much as possible.
  3. Mobalized
    Mobalized Member
    98
    27
    Aka the only way to maintain speed without hawk eyeing the speedo
  4. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Keep in mind that you will almost always sacrifice mileage using cruise control.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I think that's a quirk of the Prius and not necessarily of a CVT. That's why there is PWR mode. That'll save you some foot pressure. Hondas are usually light touches while Toyotas need a heavier foot. That's been my experience anyway.
    iPhone ? - now Free
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Every car I have ever driven needed more gas to go up a hill. If you have your Prius in ECO setting then you will need even more pedal travel to maintain speed. Try the power setting if you want to have less pedal travel.
  7. hlunde
    hlunde Member
    419
    74
    Since the Prius engine speed and road speed are completely unrelated, cruise control is your friend. In "conventional" vehicles with either a manual transmission or a locked torque converter, a change is road speed can often be detected by a change in engine tone. The Prius engine is fairly noisy and its tone means nothing.
  8. fuzzy1
    10,172
    Perchance, have the other cars you've owned (except the Del Slow) had 6 or 8 cylinder engines?
    If you try to push a car up and down the hill, you should find that it takes far more power to maintain a given speed uphill than down. With an engine that efficiently produces power with little wastage, this means considerable adjustment to the pedal.
    Old style engines are very wasteful, and that waste is quite variable, depending on conditions. That variable waste filters out some of need for pedal adjustment, more so with larger engines. A consequence of Prius' much greater efficiency is far less natural filtering.
    ftl likes this.
  9. Mobalized
    Mobalized Member
    98
    27
    Every car I am comparing it to is a 4 cylinder, I won't compare to my Sti because that isn't fair. But the 100 HP Del slow seems fair.
  10. fuzzy1
    10,172
    But if they are all Atkinson cycle engines, they still have that wasteful and variable drag that causes some load filtering.
  11. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    I would floor my Mazda GLC about a mile before the Peasley Canyon on Washington State 18, and be doing 80 MPH at the base, but once I was 2/3 up I had to shift to 3rd and never got above 35 again until I5.[​IMG]
    The Prius is way more powerful.
  12. Mobalized
    Mobalized Member
    98
    27
    I'm not even venturing into talking about large hill climbs, because quite honestly it's a prius I knew what I was getting into on hills. Plus it's no worse than the Del Sol there. However, I'm talking about small short sections of increased grade. It's the only car I've encountered that can hit a small knoll and require constantly more pedal. On inclines I'm either accelerating or decelerating no constant speed.
  13. drysider
    823
    332
    Liberty Lake WA
    Which is why I do not watch RPM's but I do watch MPH. Cruise is a good thing but it will cut 10% or so off of your mileage...especially in hilly terrain. Most of the driving methods are easy vs. higher mileage.
