Maintenance 100k Miles
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Zaven, Sep 30, 2021.
  1. Zaven
    Zaven Junior Member
    Los Angeles
    2019 Prius
    L Eco
    Hello, I have a 2019 Prius eco with 100k miles. Have only done oil changes till now. Did some research and decided I'd do some preventative maintenance @ 100k miles.
    Wanted to replace the brake fluid, trans fluid and replace all spark plugs. So I called my local toyota dealership and was told to not change the spark plugs till 120k, was also told that the transmission is sealed and the fluid never needs to be replaced (contrary to what I've read on these forums).
    I didn't want to push the trans fluid issue with them, should I just find another dealership or mechanic to do the trans fluid replacement? Seeing as I drive almost 50k miles a year.
    Thank you
  2. Mendel Leisk
    42,116
    Plugs are not due,till 120K miles, per the Toyota schedule.
    For the transaxle fluid change I won't even bother debating the dealership garble point-by-point: it's a simple drain and fill. Car should be raised and level. Have two replacement washers (for the fill and drain bolts), and 4 quarts/liters of Toyota ATF-WS. Tools: long-handled ratchet wrench, torque wrench, 3" extension (just in case), 10mm Allen Key style "socket" (the fill/drain bolts are socket-head cap screw style), and some method of getting the fluid in. Dead-simple is a funnel with at least 3 foot hose extension (keep OD of hose to 5/8" or less), for fill from above. You'll also obviously need safety stands and floor jack (can do the front on ramps, but should still raise the rear to achieve level). Fill (again, with the car level), till fluid starts coming back out.Repair Manual info attached.
    Did they not comment on the brake fluid? Dealership will (or should) not charge much over $100. Or you can DIY. Watch @NutzAboutBolts video on the topic, third gen but very similar I think. Non-Techstream method is what I've done, think it's fine for simple drain/fill. Repair Manual info attached.
    thomassster likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The Maintenance Manual which came with the car specifies what needs to be done, when. Scary that it's only had oil changes till now.
  4. Mendel Leisk
    42,116
    Brakes for starters…
    the pat response is “they inspect them every time they rotate the tires”. That visual inspection is not a full brake service. Toyota USA recommends a brake service (vaguely), every 30k miles or tri-yearly, whichever comes first. In the warranty and maintenance booklet.
    alanclarkeau likes this.
  5. Doug McC
    Doug McC Senior Member
    1,087
    427
    Midwest
    2022 Prius
    From the 2022 Maintenance Schedule for 36month/30000 miles:
    MAINTENANCE LOG
    ■ Check installation of driver’s floor mat ■ Inspect and adjust all fluid levels1
    ■ Inspect HV battery cooling intake filter6 ■ Inspect wiper blades
    ■ Replace cabin air filter
    ■ Replace engine air filter
    ■ Replace engine oil and oil filter2 ■ Re-torque drive shaft nut (AWD) ■ Rotate tires
    Inspect the following:
    _ Automatic transmission for signs of leakage
    _ Ball joints and dust covers
    _ Brake lines and hoses
    _ Brake linings/drums and
    brake pads/discs4
    _ Drive shaft boots
    _ Engine/Inverter coolant5
    _ Exhaust pipes and mountings
    Driving on dirt roads or dusty roads:
    _ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    _ Fuel tank cap gasket
    _ Radiator, condenser and/or intercooler _ Rear differential oil (AWD)
    _ Steering gear
    _ Steering linkage and boots
    30,000 miles or 36 months
    _ Additional Maintenance Items for Special Operating Conditions3
    ■ Tighten nuts and bolts on chassis and body
    Driving while towing, using a car-top carrier, or heavy vehicle loading:7 ■ Tighten nuts and bolts on chassis and body
    Dealer Service verification:
    Date: Mileage:
    1 Inspect sealed transmissions, transfer cases and differentials for signs of leakage. If any leakage from a sealed component is suspected, it is recommended that you have the sealed component inspected by a Toyota dealer. Inspect power steering fluid (if equipped) and brake fluid level/condition. Inspect engine and inverter (if equipped) coolant level/condition/freezing point. Your dealer may recommend services (Dealer-Recommended Maintenance) based on inspection results.
    2 Reset the oil replacement reminder light (“MAINT REQD”) or the message “OIL MAINTENANCE REQUIRED” on the multi-information display after maintenance at every 5,000 miles.
    3 Perform these service items only if you drive primarily under the conditions indicated.
    4 Inspect thickness measurement and disc runout.
    5 Refer to “Engine/Inverter Coolant” in the “Explanation of Maintenance Items” section in the back of this guide for more information.
    6 Visually check the HV battery cooling intake filter for dirt or dust every 5,000 miles and clean if necessary. Clean every 20,000 miles.
    7 Not all vehicles are designed for towing. Refer to your Vehicle Owner’s Manual for details.
    Maintenance Log 41
    Inspect? Service?
    #5 Doug McC, Sep 16, 2022
  6. Doug McC
    1,087
    427
    Midwest
    2022 Prius
    For 100000 mile (same document):
    100,000 miles or 120 months
    ■ Clean HV battery cooling intake filter6
    ■ Replace engine/inverter coolant4
    ■ Rotate tires
    ■ Visually inspect brake linings/drums
    and brake pads/discs
    ■ Inspect ball joints and dust covers
    ■ Inspect drive shaft boots
    ■ Inspect engine air filter
    ■ Inspect steering linkage and boots
    and body
    and body
    4 Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter
    Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter.
    I can’t imagine a dealership refusing to do a transmission service if you request it, it a money maker for them and your money. Just ask them to do it.
