Maintenance advice: needed
Discussion in 'Gen 3 Prius Technical Discussion' started by Ma23peas, Jun 29, 2017.
  1. Ma23peas
    Ma23peas Junior Member
    daughter is taking our 2010-V Prius to college.
    Always used full synthetic changed oil as needed and replaced front brakes and replaced rear drum rotors??
    We are at 210k and here is what we think is needed to send her off safely:
    Flush radiator
    Change spark plugs
    Replace plug wires ( does ours even have them??)
    Struts? Car is not bouncing, but struts generally recommended? 80% of our miles were interstate
    Replace filters...
    Anything else? I do plan on putting pro guard in the next tank...any things I am missing?
    52,915
    welcome!
    can you give us an idea of what maintenance the car has had? did it get the full, 100k and 120k? has it had everything since then?
    you're ready to do them all over again.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Go to our YouTube channel and do all of the maintenance we posted. Most likely you'll need all fluids change, air filters, check front and rear brakes and lube if needed or change them out, pcv, HV fan cleaning, spark plugs, no need to change the ignition coils because they're controlled by the ECU and don't need to change unless there's a CEL indicating there's a problem with them. Wiper inserts, check tires to see if it needs to be replaced. Check alignment for any issues. Don't think struts need to be replace unless there's issues with them.
  4. Zulat
    Zulat New Member
    Portland Oregon
    Ditto on the HV fan cleaning.
  5. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Don't forget to juice the tires for her...
