Maintenance Costs on a Prius?
Discussion in 'Gen 3 Prius Main Forum' started by Bman83, Apr 16, 2013.
  1. Bman83
    Bman83 Junior Member
    39
    Los Angeles
    I have an appointment to trade in my wife's Camry for a Prius tomorrow evening. I was curious if there are any maintenance items on a Prius that cost more than usual. I've been told that the Tires wear faster by a friend but I think that's bogus. I figure tires will be Cheaper to replace as her Camry has 16" and the Prius has 15" wheels I believe.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Well the first 25k miles the maintance is free, my orig spec tires, now with 27k miles. I expect, at the current rate will last to 45k. I've gathered from this forum that brakes last approx 100k, and in California your Hybrid battery has a 10 year 150 mile warranty.
    I'm expecting my maintaince will be lower than my last car, a 2001 Camry Solara Convertible. The gas cost is certainly waaaaay down.
    The one pricy item is the 12 volt battery, which is expected to last 4 to 6 years and will cost between 2 and $300 installed.
  3. frodoz737
    frodoz737 Top Wrench
    4,765
    2,539
    33
    OEMs tires will last around 40K +/- miles, like most new cars. Most other "maintenance" items are on par with regular cars, but remember to maintain it. Lot's of good reading hear, but do not fall for the no maintenance needed for 100K BS. You'll be happy with the Prius if you liked the Camry. Not as luxurious but great mileage. ;)
    52,651
    but the only maint. needed for the first 100k is oil and filters plus tire rotate, correct?
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    70 for synthetic oil change or diy
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    No.
    Inspections are frequent. I would personally change the ATF at 30,000 miles, then every 60,000 miles.
    I would change the 12 volt battery every 5 years.
  7. Bman83
    39
    Los Angeles
    How many miles do the recommend an oil change? My wife has a 09 Camry and changes it every 5k miles with a regular oil but my brother has 10' Camry and has to use synthetic oil though its every 10k miles
  8. BZzap!
    BZzap! Senior Member
    1,607
    878
    Same for the Prius, 10K miles for oil and filter change.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Maintenance+repairs is dirt cheap. This is my all-inclusive spreadsheet covering 8.5 years and about 152k miles. It is working out to right about 1 penny a mile.
    Tyres will last a long time if you check pressures when you fuel up and inflate closer to sidewall maximum rather than the mushy pressures Toyota recommends.
  10. Batavier
    Batavier Member
    442
    The Netherlands
    My first Prius (2004) is still using the same 12V battery, after 290,000 kms. No problems whatsoever. In the Netherlands the Toyota dealers use the same maintenance schedule (and prices) as the Vitz for the Prius2. Not sure what the prices for the Prius3 are, but probably comparable.
  11. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Well a base model of Camry is a lot LESS luxurious than a base model of Prius Two in my opinion. I had one while my 3 days old 2012 prius' front bumper was fixed !!! I do not remember which model LS or something but I know that was the lowest model maybe 2011 something. Did not much like the ride either.
  12. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    One thing with the new prii that you don't have to have replaced... like EVER are belts. No serpentine or accessory belts period!
  13. tankyuong
    1,555
    662
    Central MO
    And 200000 mile brakes
