Maintenance Mode
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by xerox6135, Jun 1, 2012.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Maintenance mode. What can be checked in this mode or does it just disable the traction control . My c is a two no nav
  2. xerox6135
    xerox6135 Member
    170
    93
    michigan
    wow this is a 1st that no body has a thought or a anwser lol
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    umm.. i'm not quite familiar with what you're talking about..
  4. xerox6135
    xerox6135 Member
    170
    93
    michigan
    prius c turn key to on not ready hit gas pedal 2 time in park 2 times in neutral 2 times in park turn key to ready then you will see Maintenance mode on the display traction controll will be disable
  5. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    The purpose of Maintenance mode are:
    • Inspection of ignition timing etc. when performing engine maintenance, idle speed exhaust emissions testing (CO, HC), etc.
    • Tests using a speedometer tester, two-wheel chassis dynamometer, etc.
    It keeps the engine idling when park (P) is selected and also cancels traction control.
    Test items in Maintenance mode depending on [Shift State] are:
    1. Vehicle straight travelling test (side slip inspection) - [D]
    2. Braking force test - [N]
    3. Speedometer test - [D]
    4. Exhaust gas test (idling) - [P]
    5. Headlight test - [P]
    Caution: You should cancel Maintenance mode immediately after completion of inspection. Driving the vehicle without canceling Maintenance mode may damage the transaxle. Do not perform rapid starting or quick acceleration on a speedometer tester. If rapid starting or quick acceleration is performed on a speedometer tester, damage may occur to the transaxle.
    Vincent
  6. xerox6135
    xerox6135 Member
    170
    93
    michigan
    thanks for the info I just knew you guys would know
  7. Toyotatechjmi91
    Toyotatechjmi91 New Member
    Utah
    If it has any DTC related to the hybrid control ECU it WILL NOT ENTER Maintenance Mode. You will have to clear the code first to enable maintenance mode You may also have to use a Toyota Techstream to talk to the Hybrid control ECU
  8. Muhammad Nadeem
    Muhammad Nadeem Junior Member
    Pakistan
    Maintenance mode is taking a quite long time. Is it good or I should turn the car off
