Maintenance on high mileage old girl
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marcy, Nov 17, 2012.
  1. Marcy
    Marcy New Member
    Bremen, GA
    I
    No, not me!! My 2005 Prius that has 234,000 miles on it. I used to be fanatical about having extra services done at nearly every oil change or warranty service interval.
    But after I had the drive built replaced proactively @ 166k miles I just kind of used my common sense. We did have to have the main computer replaced in April 2012 @ 210k miles - but absolutely no problem since then.
    All maintenance has been done at the dealership - though I plan to do the oil and filter changes now thanks to some very helpful videos I found.
    Anyone have experience with a high mileage Prius (Gen II, I guess) and advice on what services to get done preventatively?
    Thanks for your guidance -
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I would do the test to see how well your 12 volt battery is.
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    It is free, simple to do in your own driveway/garage and better than the dealer.
    I would consider changing the Transaxle fluid with 4 (you may not use all of the fourth) quarts of ATF WS from the Toyota Parts man (and 2 washers for the fill and drain plugs) for about $50
    As a Dealer service expect to pay about $125 and to meet resistance that the service ever need to be done. (I say every 60,000 miles)
    Yahoo! Groups
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
