Maintenance on Prime battery fans, a little help
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by estebinbin, Dec 10, 2020.
  1. estebinbin
    estebinbin Member
    184
    47
    Hello, I have a 2017 Prius Prime and I would like some guidance, tips, videos, photos, anything to help with the maintenance of the traction battery fans in the Prime. I have seen other threads where other owners of other Prius models discuss this but little on the Prime.
    I keep getting bugged by my dealer about their maintenance service for the battery fan system but I am not convinced due to the price of their service and that my Prime has not notified me that service is needed, also since I am not sure when this service should be done.
    Through the manual, other threads and videos I have been able to get an idea where the fans are and how to get to them. I am not a very mechanic kind of person but I feel this should be possible at least to check the the fans are dirty.
    Any help will be greatly appreciated.
  2. estebinbin
    estebinbin Member
    184
    47
    Ok to continue on what I have been able to do. I have checked the two air vents on either side of the backseat. Pop those open and check the filters, all looks clean, I could assume that the color of the filters being gray or blackish is natural.
    Next I was able to take apart some of the coverings in the trunk to reveal the battery and what I believe are the two fans, one on their side of the battery, that move the air. Here is where it was interesting for me and my non mechanic skills. The fans are connected to vent tubes that go to the back seat vents and also to the back of the battery, by this I mean the part of the battery that is facing the back bumper. Each fan has a bolt clip and cover clips around it, 4 I think, that hold it into this whole vent tube mess. I am not sure if I have to try and take these tubes apart from the fans to be able to see inside the fans and their dirty condition. Or can they be slightly worked in a way to peek inside and check their cleanly ness? They are also connected to power and I was unsure of how to unclip the with force and fear of breaking something. Again any words or visuals of help would be great. Thank you for your time.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    It's pretty simple to take of the cargo deck. I don't have pictures of the disassembly, but it uses the pop up plastic fasteners like the ones securing the panels under the car. Once you have that off and remove the plastic storage bins on either side plus the one at the back for the EVSE cable storage, they are easy to spot. Then unplug them and take out the mounting fasteners. The PiP was much easier, but these aren't bad.
  4. estebinbin
    estebinbin Member
    184
    47
    Sorry I am not using the correct terminology or describing it badly.
  5. estebinbin
    estebinbin Member
    184
    47
    Thank you for the pictures. I did get to this point, that is when I started to question what I would have to do or how much more I needed to disconnect to see inside the fans.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    Sorry that I don't have time to investigate. That's also as far as I went since I was confident they were OK based on how clean the fans stayed on my PiP. I just wanted to see how hard they were to access. They don't look to me like they are hard to remove.
    estebinbin likes this.
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    As long as the filters are somewhat clean, don’t worry about it, sure there may be a very think layer of very very fine dust that could pass through the filter.. but it’s not worth it.
    2017 is still like new to me! Change the filter and call it good!
    Older generation Prii were a different story since they didn’t have filters, and in the case of a dirty car or pets, it would almost be like a vacuum sucking in all the dirt.
  8. Salamander_King
    Salamander_King Senior Member
    11,019
    8,953
    New England
    AFAIK, the battery fan system maintenance is not listed on the scheduled maintenance. I don't think PP has any specific notification for the battery fan system maintenance. Just curious, how much is a dealer asking for this service? I am with @Aaron Vitolins on this that as long as the intake vent filters are clean I am not going to mess with the fans inside. The replacement filters are cheap, IIRC ~$5. If they are dirty, just replace them and call it done.
    Note: You will need Left and Right filters. They are different parts.
    part #G92DH-47080
    part #G92DJ-47010
  9. estebinbin
    estebinbin Member
    184
    47
    I will try to find where I wrote down but I think it was around $270. The filters on the next to the seats were pretty clean, no hair and no major dust when I shock them. What is the part number or where can these be purchased?
  10. Salamander_King
    11,019
    8,953
    New England
    Parts numbers for the filters with links are in my previous comment.
  11. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    most all filters are synthetic plastic and can be washed with soap and water. At least that's what I do.
  12. RockOnly
    RockOnly New Member
    Boston
    2019 Prius Prime
    Estebinbin - how did you pop the air vents below the back seats open? I'd like to look at my filters but I don't want to break the plastic covers trying to get them off...
  13. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    upload_2020-12-27_17-48-19.png Page 570 2020PP manual
    Tideland Prius and jerrymildred like this.
