Maintenance required for traction battery
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by faqirachmad, May 12, 2019.
  1. faqirachmad
    faqirachmad Junior Member
    GB
    Business Edition
    Hi everyone, i have got this warning on my dashboard i can't find the fan for hybrid battery!? I have got Prius gen 4. If anyone can help thanks IMG-20190505-WA0002.jpg
    TA-1052 ?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is the filter clogged (or the vent covered?
  3. faqirachmad
    GB
    Business Edition
    I don't know
    TA-1052 ?
  4. alanclarkeau
    7,045
    7,593
    Not sure if you've got the EURO Manual or a specific UK version - this is the EURO:
    TOYOTA also advise some more information:
    It's the one on the Driver's Side of the front of the back seat - check that you haven't got something on the floor or hanging over the edge of the seat (like a dog blanket, children's schoolbags?) which are covering it. There's another in the middle - which seems not to be so critical, but I keep it uncovered too.
    They only suggest the corner one is the one to watch and there's a filter behind the grille. I got mine off easily to check, with a bit of fiddling but the filter was like new.
    faqirachmad likes this.
  5. Mendel Leisk
    41,865
    Found this also in Owner's Manual:
    I would take a crack at cleaning the filter yourself.
    #5 Mendel Leisk, May 13, 2019
    faqirachmad, snead_c and alanclarkeau like this.
  6. faqirachmad
    GB
    Business Edition
    Thank you i have cleaned the filter it was proper clogged. I hope it doesn't show that sign any more. Once again thanks everyone
    TA-1052 ?
    krmcg and Mendel Leisk like this.
  7. alanclarkeau
    7,045
    7,593
    Good news - I'd guess you shouldn't see that again. How many miles have you done?
    It could be worth a diary entry to do it again - maybe twice as often. My suspicion it will run more efficiently if the filter is clean.
    I checked mine at about 30,000km and it was clean as the proverbial whistle. But then, my dogs are non-shedding (and only occasionally in as passengers); I rarely have passengers in the car (hopefully non-shedding too), always have A/C on.
    Mendel Leisk and faqirachmad like this.
  8. faqirachmad
    GB
    Business Edition
    Thanks mine is 50,000miles
    TA-1052 ?
    alanclarkeau likes this.
  9. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    If the message doesn't go away, unhook the 12 volt battery for a few minutes.
  10. alanclarkeau
    7,045
    7,593
    I think cleaning the filter should have done it - better than disconnecting the 12 volt if not necessary.
  11. faqirachmad
    GB
    Business Edition
    The message is gone not showing anymore. Thanks everyone
    TA-1052 ?
  12. bisco
    52,351
    do you carry shedding animals? what was in the filter? that is very unusual.
  13. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Ok... Ok... I just HAVE to ask. :confused:
    Why does "TA-1052 ?" appear in every single one of OP's posts?! Its making me uncomfortable not knowing. lol
  14. krmcg
    2,592
    2,392
    Whittier, CA
    Google says that it is a Nokia Phone model...
    Raytheeagle and alanclarkeau like this.
  15. Mendel Leisk
    41,865
    There's some browser add-on doing that, I forget what it's called.
  16. alanclarkeau
    7,045
    7,593
    I'm fairly sure I've seen APPLE mentioned in the same place.
    Or
    Which is a Samsung Galaxy S9 I think
    Or just
  17. alanclarkeau
    7,045
    7,593
  18. Mendel Leisk
    41,865
    When I first accessed priuschat on a newly acquired smart phone (with its regular browser) I got a pop up suggestion to install tapatalk. I tried it, saw no advantages over the regular browser, quit with it.
    But who knows, might depend on the phone.
    Sent with an iPhone :rolleyes:
  19. alanclarkeau
    7,045
    7,593
    When I bought a new laptop a couple of months ago, DELL took ages setting it up - it thought that I'd certainly want voice commands, SKYPE and all sorts of other things which I'd not heard of - and couldn't see the sense of.
    But - it didn't bother setting up the scanner and printers which were plugged in - no, the useful things, I had to do myself.
