Maintenance Required Indicator
Discussion in 'Prius v Fuel Economy' started by prevee5, Jul 11, 2017.
  1. prevee5
    prevee5 Member
    122
    Monrovia, California
    I have a 2012 Prius v 5. At about 70K miles.
    Was wondering if there's any correlation between the Maintenance Required Indicator Light and fuel economy.
    My light came on at a 7500 mile interval I believe to indicate I'm due for an oil change. I usually wait till around 10k interval to do the job. Oddly enough, when the light came on, I noticed avg MPG dropped from around 42 to 35 or so. Anyone?
    Thanks!
  2. Air_Boss
    Air_Boss Senior Member
    4,263
    1,197
    New Yawk
    No obvious correlation unless delayed response to the MRI triggers 'drag' on the hybrid system. Doubtful, but what a scandal that would be...
    52,925
    nope. start with your tyres pressure, air filter and 12v battery. the main. reminder is every 5k from the last reset. your o/m shows the actual maint. required every 5k.
