Maintenance Required
Discussion in 'Gen 2 Prius Technical Discussion' started by Mike Jossa, Aug 6, 2019.
  1. Mike Jossa
    Mike Jossa New Member
    Lago Vista, tx
    Recently replaced the oil in a 2007 Prius with full synthetic 5W-30.
    Now I’m getting the maintenance required warning light. Any ideas why?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Yes in your owners manual it will tell you the light will go on after 5000 miles and how to reset it. I suggest you check your owners manual.
    Raytheeagle likes this.
  3. vegliare
    vegliare Junior Member
    Greenacres
    Same as above. You have to manually reset the light. Check owners manual or YouTube. Very simple fix
  4. deletejunkemail
    deletejunkemail Junior Member
    Youtube or this:
    Maintenance Reminder Light - Turn Off
    • Turn on car and change dashboard to show Car Mileage (Not Trip Mileage). Use the "ODO Trip Button" to show this on the dashboard which is to the right of your Hazard Light button.
      • Turn car off
    • Foot OFF the brake
    • Hold "ODO Trip" and Press Power Button 2x
      • Should Go Away
    • Turn car ON as normal and Maint Lights should be gone
    NORMAL POPS likes this.
  5. Mike Jossa
    Lago Vista, tx
    Appreciate the replies.
    Tried the reset protocol, but still have the warning light.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Try again. missed something.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The reset procedure might be slightly different depending on model.
    But if the above is correct for your year model, read it carefully and follow it exactly.
    I had to make a couple of notes in the margin of my manual to get it right in the future.
  8. Mike Jossa
    Lago Vista, tx
    Got it canceled. Thanks.
    Skibob likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    your posting in the G2 forum you own a G3.
  10. deletejunkemail
    Did the guide i provide work? It should but please confirm for future folks finding this thread.
