Maintenance required
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Mikhail Bond, Jan 12, 2020.
  1. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Hello all,
    my Prius prime with 125k miles just gave me a notification that says maintenance required, visit dealer.
    It does not specify for what...
    anything that can clue me in?
    The infotainment system doesn’t show anything in the car section for oil etc..
    I don't have the history on my car since I bought it from Toyota with 110k miles on it.
    52,396
    every 5k, toyota programs in that message for basic service.
    you can find it in your maintenance schedule
    do you know the service for the first 110,000 miles?
  3. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I have a carfax and it stated.
    alignment
    cabin air
    oil and filter
    maintenance inspection
    vehicle serviced??
    that's about it. I can call them tomorrow and maybe get more details.
    I doubt they ever changed the ATF fluid, so maybe I should start with that.
    52,396
    go to toyota.com/owners
    sign up and enter your vin
    it will give you all historical dealer service
    jerrymildred likes this.
  5. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Hmm,
    6/18/18
    Provider
    Miller Toyota of Anaheim
    Service Type
    Dealer
    Mileage
    24,391
    and then nothing.
    Carfax shows a visit at my local toyota dealer where I purchased with a 110k mileage mark.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    It sounds like you are not the original owner of this car. For sure routine maintenance (lube and oil, tire rotation, etc) is called for, but aside from that, you may be due for high mileage services such as coolant change and spark plugs.
    As @bisco stated, you can check the previous service history from the Toyota site. Just a word of caution is that any service record of repair or routine maintenance may or may not spell out exactly what was done or replaced. Just because it says "routine 120K maintenance" does not mean spark plug was changed at that time. So you may still have to check it yourself what service is still needed.
  7. DavidA
    2,348
    1,823
    Chicago western burbs
    Well first, congrats to you and the previous owner getting 125K on the car. That's encouraging the rest of us. Good points by those above on suggested items to check and service. There should also be a maintenance booklet, or one online, that has things to check at mileage intervals.
    The cabin air filter takes one minute to change yourself. Probably about $20 if you buy that from a (good) dealership. The OEM is not easily found online, and those that state that similar types fit are probably incorrect. Took me a month to discover that the hard way. It was about two dollars more at the dealer and was a perfect fit. Videos online on how to change it out yourself.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I seem to remember someone here talking about having over 100k on their Prime already. I wonder if he traded it in. I think he was a salesman. Not sure how to search for something like that.
    Anyway, the only thing close to challenging for a DIYer on the 120k mile list might be the spark plugs. But they are way way way easier than on a Gen 3. Oil and filter will require some effort, too, but not that hard once you figure out the handiest way to get the car up so you can get under it. Lots of threads here about it. And the two air filters should take less than four minutes total for both of them.
  9. Salamander_King
    11,024
    8,970
    New England
    Are you thinking of the OP of this thread? He just changed the spark plugs on his 2017 PRIME, at 95K miles.
    Just changed the spark plugs in my Prius prime 2017 | PriusChat
  10. jerrymildred
    11,517
    14,158
    Tampa, FL
    BINGO!!! That's the one. And I remember being super-pleased that Toyota finally decided it didn't really have to be a major ordeal to get the plugs & coils out and back in. Thanks, SK. (y)(y)(y)
    So it was Portland. Probably not the same car. But it was the left coast. I had that right at least. LOL!
    Salamander_King likes this.
  11. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I just installed a hitch on the prius, I think ill manage with the spark plugs.
    So far on my to do list
    1. Spark plugs
    2. Tranny Fluid
    3. Lift Kit 30mm
    4. Sound Insulation
    optional(5k left?)
    5. Oil and filter(maybe upgrade to screw on)
    6. Air filter
    7. Cabin air filter
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The maintenance reminder is a simple mileage counter that repeats every 5,000 miles since it was last reset. It does not track time elapsed, only miles driven. Also, it does not know anything about what has been done to the car or what is needed next.
  13. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Just checked with dealer.
    They said I’ll need to do the spark plugs, engine coolant and inverter coolant.
    650.00 for those three items.
  14. bisco
    52,396
  15. jerrymildred
    11,517
    14,158
    Tampa, FL
    Those are chores that don't take a ton of money for materials, but do take some time to do right even though they are not hard at all. Still seems like a pretty steep labor rate to me.
  16. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Which brand hitch did you install?
    Lift KIt?!
    Does anyone make a specific kit for Prime?
    What's your reason for doing this?
  17. jerrymildred
    11,517
    14,158
    Tampa, FL
    That caught my eye, too. I would love to have my Prime have about one more inch of ground clearance. Maybe even 1-1/2".
  18. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    The hitch I installed was from Etrailers.com took me about an hour and a tiny bit of trimming the underpan.
    I also took the chance to 3m rubber Bedliner on the metal body while I was down there to reduce road noise.
    Draw-Tite Sportframe Trailer Hitch Receiver - Custom Fit - Class I - 1-1/4" Draw-Tite Trailer Hitch 24966
    passengers opening my door always hit a curb or get stuck on grass once they sit in the car.
    the stock height is 4.95 inches of ground clearance.
    https://tema4x4.com/catalog/prostavki/filter/mark_ts-is-toyota/model_ts-is-prius/year_ts-is-2018/apply/
    see my post.
    Prius Prime Lift Kit | PriusChat
    #18 Mikhail Bond, Jan 15, 2020
  19. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    if you install the parts TOY-15-013 + TOY-15-056/30, it would give you about a 1" lift.
    or you can be like this guy...
    Darn that low ground clearance | PriusChat
  20. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Here are my 125k spark plugs
