Maintenance reset
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Spaded, Apr 8, 2015.
  1. Spaded
    Spaded New Member
    I got a new (to me) 2012 prius, only problem I have right now is the maintenance reminder will not reset. I've worked as a lube tech for the last 3 years so I can reset almost anything under the sun. I have reset these before, mine will simply not reset. I have gone thru every reset procedure (using the trip/odo button and using the mph/kmh button) I have found on this prius step by step multiple times multiple ways. I even connected a Snap-On solus scanner and tried hard resetting it thru the onboard system to no avail. Is there some issue with these? Or possibly something I missed?
    Cheers! :)
    52,519
    not that i can think of, are you using the o/m procedure?
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Can't say about that model but I read the book on my C, tried it several times and then..............
    Went back to Toyota and the first two service advisers couldn't do it either.
    They got a guy from the back and he did it while I watched.
    Seems like there was a TINY little thing I was passing over in the written procedure.
    Or to put it another way, do exactly what it SAYS, not what you think it should be saying.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Make sure you are viewing Trip A (not ODO) on the DISP button. Power OFF the car. Then leave your foot OFF the brake and hold down the km/miles button while pressing the power button TWO times. Keep holding the km/miles button while the display shows the maintenance reset progress. You can release the Power button while this is happening. I can't imagine why it is not resetting.
  5. Spaded
    Spaded New Member
    I have made sure it is in "trip a" and also in ODO as some procedures say one way and some procedures say the other. I will try this one exactly again as you have typed it here.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,752
    1,780
    Bay Area
    It's supposed to be on "Trip A" then you turn off your vehicle, hold the mph/kmh button and press the start button twice, then the reset light should reset itself on the odometer.
    Here's a video, just scroll to 7:14 to see how I reset the light.
    #6 NutzAboutBolts, Apr 8, 2015
  7. Easy Rider 2
    1,584
    258
    Ocala, FL
    Well I can't either. Infinitely easier than.......just pushing a single button, for instance.
    :ROFLMAO:
    Spaded likes this.
