Maintenance Rip-Off?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by carlbarry, Oct 10, 2019.
  1. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Free inspections are repair estimates.
    “Homie don’t play dat”- Homie Da Clown (In Living Color)
    carlbarry likes this.
  2. Mendel Leisk
    41,889
    Sadly, that's likely right.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The manufacturer is very limited what they can do TO a nonperforming dealership, they mostly just quit doing things FOR dealerships that do not perform up to par.
  4. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    There a saying for that:
    "If you can't dazzle them with brilliance, baffle them with BS."
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Your opinion.
    I quite assure you that there ARE completely honest dealers out there........although finding them can be very hard sometimes.
    NutzAboutBolts and Mendel Leisk like this.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My dealer (Kirk Toyota in Grenada MS) has even come to me and said, this air filter is not that dirty, can we look at it again in 10,000 miles and change it then? They not only do not upsell, they discourage me from 'uneeded' service (like ATF WS changes) and recommend delaying scheduled service.
    Sadly anecdotes are not always trends.
    Raytheeagle and carlbarry like this.
  7. bisco
    52,373
    i have read stories about honest dealerships. or maybe it was a dream...
    dig4dirt likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't know what maintenance your vehicle may or may not need. But if you brought it in for a recall, oil change and an inspection, that's what you should get.
    My first reaction is, if they didn't do an inspection how do they know all the things they are saying you need,- you need?
    I find it hard to believe a vehicle with only 20,000 miles on it, is in such bad shape that it just wouldn't pass an inspection in totality.
    Pretty much just because I don't like that response, I'd go to a different service center.
    There's nothing wrong with an HONEST inspection, there's nothing wrong with really needed maintenance. But don't tell me you didn't inspect the vehicle BUT I need a whole lot of maintenance.
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,729
    1,767
    Bay Area
    not really my opinion since I’ve worked at a Toyota dealership before. They have a quota to hit per month because that’s what the GM wants. All service writers have to make a Certain quota to get a bonus pay. I know some service writer don’t push to up sell but then they don’t get a high bonus check like the ones who do up sell.
    if you come in as a customer and know what you want, they won’t push you on upsell, but if they’re going to inspect or service your vehicle, they will recommend things that you need or don’t need.
    RMB and Mendel Leisk like this.
  10. carlbarry
    carlbarry Member
    63
    26
    Nassau County
    Well, for example, they said the HV Fan needed service. Did they really take apart enough of the car to check that? Did they check the fluid to see if the car really needs "inverter service"? I kind of doubt it. But I do know people who when told things like that, get nervous, and accept the recommendation. "Oh, my interior air filter is dirty and I can get sick? And it's only $75 to change it? Please, go ahead."
    mikey_t and bisco like this.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sounds like you are lacking a basic understanding here.
    The extensive experience that you had at ONE SINGLE dealership does NOT mean that is the way it works at every OTHER one.
    Just taking a wild guess: There are 50 states and maybe 10 dealers per state so there are a minimum of 500 dealers in the US. Probably a lot more. For your statement to be valid, you would have to have intimate knowledge of EVERY one of them.......and I'm pretty sure that is NOT the case.
  12. NutzAboutBolts
    1,729
    1,767
    Bay Area
    And yet we always read about these types of thread where people get upsell at the dealerships for services that they don’t need. That is fact and not opinionated.
    Raytheeagle, RMB, bisco and 1 other person like this.
  13. bisco
    52,373
    my guess: 95% dishonest
    NutzAboutBolts likes this.
  14. bisco
    52,373
    no, they don't look at the fan first, that's 99% of the job :p
    same for the cabin filter
    alignment: should notice uneven wear on the tires, or pulling to one side
    tranny fluid? they used to tell customers it was lifetime. i guess they found a new profit center :cool:
    Grit likes this.
  15. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    With regard to the cabin filter. Will they skip filter inspection/replacement if so instructed. I just installed a K&N reusable filter and applied the "STOP" sticker instructing not to discard. I'll be cleaning the filter myself IAW warranty.
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I do not know which dealership you use, but it will depend on the dealership. No one can guess what 'they' will do.
    ice9 likes this.
  17. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Yeah. The simple answer is usually the correct one: Ask the dealer. Thanx.
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    No it is not "always".
    And you are taking a few facts and then representing your CONCLUSION as fact.......when it really isn't......or might not be.
  19. bisco
    52,373
    just tell them you already did it. they have no right to do anything without your approval.
  20. NutzAboutBolts
    1,729
    1,767
    Bay Area
    Unless you’re an hourly Mechanic, I don’t know why someone that works flat rate don’t recommend to upsell services because that’s their bread and butter.
    Let me ask you this question, have you worked as a mechanic before? If not, then you don’t know how the flat rate and hourly pay works, if you are, then why wouldn’t you be recommending all these upsell services to make money for your flat rate pay?
