Major JBL stereo upgrade but keeping stock HU
Discussion in 'Gen 3 Prius Audio and Electronics' started by UNCLBONZ, Oct 18, 2020.
  1. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Long Island New York
    Dave , Moving your processor cable to the passenger side should address that issue
  2. audiodave
    audiodave Active Member
    800
    272
    US
    The only cables that are plugged in is the Ai-net and the bass level control cable. Both on the right of the car. The whine is very faint but still can be heard with no music and driving slow. The processor cable is on the left but left unplugged because it gets much louder. So I make adjustments and unplug it. I wonder if I can ad shielding to the Ai-net cable where it goes around the battery.
  3. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Dave do you have a stock Toyota radio or an aftermarket???
  4. audiodave
    800
    272
    US
    Aftermarket of course. That's why I'm using the Ai-net cable to get the signal to the processor and control the changer.
  5. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Then it's strange that you would have interference noise. Did you try unplugging the changer to see if that's the source??
  6. audiodave
    800
    272
    US
    I haven't. The control cable is plugged in but audio is taken from the optical out.
  7. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Did you try a new ground for the head unit ?
  8. audiodave
    800
    272
    US
    I figured the original would be best but I did have hooked up the the metal bar behind the dash first. Was the same. You hear it on acceleration and de-acceleration charging.
  9. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    Any audio cables should be ran on the driver side.
    Any and all power cables should go on passenger side.
  10. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Silly question...Have you tried turning down the gain control on the amp just to see if it gets any better???
  11. audiodave
    800
    272
    US
    Don't the hybrid battery cables run on the driver's side?
  12. audiodave
    800
    272
    US
    I haven't tried turning them down.
  13. UNCLBONZ
    UNCLBONZ Member
    256
    81
  14. UNCLBONZ
    UNCLBONZ Member
    256
    81
    The Hybrid cables run for a short distance on the passenger side then go Into the body of the car. You can see this in my post #25 photo which shows the large orange wire going from the Hybrid battery to the hole in the body under the rear seat area. The 12 volt cables run down the passenger side of the car IMG_1009.JPG
  15. audiodave
    800
    272
    US
    I have a gen 2 though.
    kenoarto likes this.
  16. UNCLBONZ
    UNCLBONZ Member
    256
    81
    Yea I don't have any pics of the Gen 2. Mine's a 3
  17. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I agree, sometimes it is as simple as accessing a new ground.
  18. UNCLBONZ
    UNCLBONZ Member
    256
    81
    A New ground is the simplest thing to try besides lowering the gain on the amp to lower background noise
  19. audiodave
    800
    272
    US
    It's grounded directly to the battery.
  20. audiodave
    800
    272
    US
    Gains not set too high. But I can try it. Takes good volume off the deck even at 4 volts pre signal to crank it.
