Major Malfunction - Need Advice
Discussion in 'Gen 3 Prius Main Forum' started by Bryan Wolfe, Jan 19, 2023.
  1. Bryan Wolfe
    Bryan Wolfe Junior Member
    Indianapolis
    I had the cruise control set traveling on the Interstate in heavy rain and was beside a semi-tractor trailer. I saw the semi move to the right a bit like he was trying to avoid something in the road. I moved to the left a bit to increase distance and suddenly I heard something under my car. It sounded like I had run over a truck tire tread and was knocking; I looked in the mirror an saw significant smoke coming from my car. I worked my way to the right shoulder to stop and began seeing smoke and smelling the odor of burning inside the passenger compartment. I could see oil on the ground. I never did see what I hit and only assumed that the semi threw something under my car that it had first hit. I towed the car to a dealer for service. I called my insurance company believing that I had struck something flung under my car. The adjustor looked and determined that I had three holes in my engine that originated from the inside out. My car is a 2010 Prius with 189K. I have owned it since it had 20K on it. The only thing I have ever had to do to that car was change the oil (always Valvaline synthetic), brakes, and tires. It has been the perfect car. Is this common? What did I do wrong? Why would this have happened? Is this anything Toyota would fix or do I just need to have a new engine put in at my expense? Thanks for your help/ideas/thoughts. Bryan in Indiana.
  2. PriusCamper
    PriusCamper Senior Member
    13,460
    5,431
    Pacific Northwest, USA
    Well, on the bright side 2010 Gen3 Prius have a horrible history of having failed headgasket and piston ring problems and it's rare for them to go very far past 200K without needing major engine work. So this is a perfect opportunity to install a 2016 or newer Gen4 engine and you'll be good to go for another 300K miles or more. There's plenty of youtube tutorials on how to put a newer engine in a 2010. Just gotta find a mechanic to do it for you. Don't deal with the Dealership, they're gonna suggest a replacement Gen3 engine that won't last as long and will probably cost you three times as much as a regular mechanic doing a 2016 engine swap.
    52,849
    call toyota and ask for goodwill warranty help. you never know
    PriusCamper likes this.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    True, but I think we have a pretty good idea. :)
    I'm not sure the OP should let the insurance company off that easy. A hole in the block usually means a thrown connecting rod and a thrown rod can be caused by excessively low oil level or no oil at all.
    So a very plausible scenario is that the OP hit an object in the road which punctured the oil pan, causing the oil leak out. The smoke was the oil spraying onto the hot engine. As the OP was getting to the side of the road, s/he was actually driving with no oil, which caused the thrown rod and the holes from the inside out that the adjustor saw.
    With an object that comes flying at the car and you hit it with no time to react, such as a piece of broken truck tire, then that is a comprehensive claim. Hitting a stationary object is an at-fault, collision claim. Obviously, a comprehensive claim is better for future rate hikes, but either way, it looks like the insurance company should pay, minus deductible.
    CR94, PriusCamper and 2010moneypit? like this.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Do you have pictures of the damage?
  6. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    This appears to be the key to it.
    When an engine throws a connecting rod, (lower end bearing failure) it tends to blow a hole through the crankcase or oil pan outwards to the world, so the description is plausible if spare. It leaves marks that are fairly deterministic and hard to fake.
    Engines tend to throw connecting rods due to lubrication failure.
    Lubrication failure has many sources, and most of them are hard to prove.
    It's plausible that you hit some debris in the road and your oil pan and/or the pickup tube for the oil pump were damaged. That could set up a lubrication failure that would ultimately result in a rod bursting out through the crankcase.
    It is also plausible that the engine was gradually burning oil and simply ran out.
    Unfortunately, it is very difficult to work out exactly what caused the lubrication failure. Front end damage that clearly extends down under to the oilpan would make an easier insurance claim.
    Just having a hole in the engine with oil on the road and a story (without dashcam video) of other motorists avoiding obstacles is a harder claim to press.
    I wish you luck!
