Makeshift Dome Light?
Discussion in 'Prius c Accessories and Modifications' started by nouveauhippy, Jan 30, 2017.
Tags:
  1. nouveauhippy
    nouveauhippy New Member
    So has anyone tried one of the stick on lights to act as a back dome light? I saw a thread that talked about changing the front lights to LEDs but I'm scared that's not going to be enough light. My 2 year is always dropping things and I doubt that's going to really help. Plus I'm not that mechanically savvy to be messing with wires and all that lol.
    What do you guys think of a stick on light that I can just stick up there and tap when I need it? The only problem I can foresee is that the heat might cause a problem. Either with the battery or the double sided tape. But I was thinking of something likes this
    or maybe this one
    Thoughts? Suggestions? Advice?
    Thanks.
  2. nouveauhippy
    Ok so I feel like a n00b but my links didn't work :confused:. Here are the links
  3. Prodigyplace
    12,720
    11,850
    Central Virginia
    The links in both postings look fine to me from my laptop.
    They do not show up browsing with Safari from my iPhone. I have seen that before. I think the forum software expects you to use the app.
  4. nouveauhippy
    Interesting. I see it on my phone with safari but I was at work (ha!) and using chrome when I posted it so maybe that was it.
  5. Prodigyplace
    12,720
    11,850
    Central Virginia
    I usually have no issue with Chrome on a PC at home or work. Perhaps some firewall or web filtering was blocking.
  6. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    It would be easy to add a dome light, just tap one of the map lights, run a wire to desired location by snaking it through the headliner with a wire hanger or something, buy a dome light for a liftback and wire it to the wire, cut out a hole in the headliner in desired location.
  7. AQUA-K
    AQUA-K Junior Member
    62
    Sri Lanka
    2015 Aqua
  8. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    IMG_6336.JPG This would be a alternative add for the interior lights
