Making an Intelligent Discharger that's compatible with prolong?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mavi, Jun 29, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So I recently squired a prolong charger with the discharge ready harness, and I don't own a discharger. I do own a turnigy reaktor 300w hobby charger. Technically can I hook that up to the prolong charger and have an intelligent discharger? Or is the only cheap method using the prolong light bulb discharger?
    Anyone know where I can buy the connector used so I can just use my own light bulb system? Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    If you’re cobbling this together, you could always sever the Prolong connector and wire things up as you see fit;).
    Saves procuring something else:).
    Or just spend the $$$ and you’re good to go(y).
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Oh I'd clobber it up and crimp together a solution.. but for some reason the harness alone is $150... making it a very expensive mistake waiting for happen.
    Raytheeagle likes this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    It’s all about perspective ;).
    If you’ve resolved yourself with piece mealing this, I’d spend some time looking into the wires and their functions.
    Good luck and keep us posted (y).
  5. JC91006
    16,936
    8,647
    Prolong bulb discharger is fairly cheap, or you can ask them to send you just the wire. I think it'll be $20 for wiring
  6. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Just the wire? As in the power connect part? Thanks for the info.
  7. JC91006
    16,936
    8,647
    Yes just the wire. Don't ask me how I know.....
    ITBland and Raytheeagle like this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Yeah the bulb discharger has a dongle cable that you connect to the existing main harness when you want to put a load across the battery.
    With that special little dongle all you need is 2 light bulb sockets and a set of bulbs and a piece of wood to mount the sockets on.
    Then go on hybridautomotive.com and print out there bulb discharge instructions.
    ITBland likes this.
