Making noise when press the brake pedal
Discussion in 'Gen 3 Prius Technical Discussion' started by Maximussss, Aug 19, 2017.
  1. Maximussss
    Maximussss New Member
    Orlando
    2010 prius. Making noise when pressing brake pedal and I can feel vibration , noise and vibration start after full stop. If I press the pedal almost till the end sound disappears.
    Here's delete a YouTube video with noise recorded.
    Please help me to understand what is the problem.
    52,927
    welcome! how many miles on her?
  3. Maximussss
    Orlando
    130k
    52,927
    might be the brake actuator. check with toyota to see if it's under extended warranty.
    amos likes this.
  5. Maximussss
    Orlando
    Thank you. I will try to visit Toyota dealer. Maybe somebody else had the same noise from the brakes?. please give me an idea.
  6. bisco
    52,927
    search 'brake actuator' to find threads from others who have had problems and solutions. i think the extended warranty ends this dec.17.
  7. Maximussss
    Orlando
    I bought it not from Toyota. I called them and they said that if i bought it not from them I do not have any warranty.
  8. Mendel Leisk
    42,386
    How often, if ever, have you had a full brake inspection. Have the rotor thickness, parallelism and run out been checked? The US schedule calls for a full brake inspection every 3 years or 30,000 miles, whichever comes first, if I recall correctly.
  9. bisco
    52,927
    dealer is incorrect. the warranty covers all prius, no matter where you purchased. you can plug the vin into the toyota owners website to see if yours is covered.
